95 RM wagon code reader
Can anyone recommend a code reader for a 95 Roadmaster Wagon?
Thanks, Roger |
Re: 95 RM wagon code reader
Are you looking for a scanner to read the codes and tell you what's wrong with your vehicle, or are you looking for something to retrieve the codes? The easiest and least expensive tool is a jumper wire placed in the "test" and "ground" terminals of your ALDL, located under your dash. You then turn the key and count the flashes on your service engine soon light. From there you can look up the codes to see what they mean. That is a brief description on how to access and read your codes. There is a little more description involved in the procedure, and it is fairly easy to do, if you are interested, I can post the whole process. Most auto parts stores sell a little tool that also takes the place of a jumper wire if you don't have one.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
^^^ that only works on 93 Pre GM cars. He'll need a scanner/reader to get his codes.
