Tensioner squeaking
There is a squeaking noise coming from my tensioner. The belt looks ok and everything seems to be fine. The tensioner does wiggle back nd forth will the engine is running but I think thats suppused to happen, I did try tightening it but it was already tightened as far as it would go. Anyone have suggestions? Also would it be ok to unscrew the screw in the middle of the pulley, take it off, and put it back on? or would that mess things up worse?
Re: Tensioner squeaking
If it wiggles on there you need to replace it. bottom line.
The bearing are going out in the pulley. You'll need to replace it soon. It can lock up and if your driving it when it does it, it could cause more damage than it's worth. no need in taking it apart. the bearing comes pre-packed for the manufacture.
Thanks SC |
The arm will move back and forth to adust the tension on the belt. Take the belt off the pulley and try to wiggle it - if there is play then you need to replace it. It's a piece of cake. Get a replacement pulley( the pulley already has the bearing in it) from Autozone or wherever remove the arm, remove the bolt holding the pulley on and do the reverse to install. I reccomend cleaning the pulley groves with soap and water to remove any grease.
2004 Explorer XLT 4.0L 4x4 1998 Ranger Supercab 4x2 3.0L Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store! Come visit me on www.faceforums.com |
Thanks for the help, I will get a new one ASAP.
By the way, I was typing in "tensioner pulley" in the parts search on the autozone website and I couldn't find one that matched. These were my options,
A/C CLUTCH PULLEY/RIM A/C COMPRESSOR BYPASS PULLEY A/C PULLEY PULLER - TOOL ALTERNATOR PULLEY BALANCE SHAFT BELT TENSIONER BELT TENSIONER BELT TENSIONER - TIMING BELT CLUTCH PULLEY/RIM - A/C CRANKSHAFT PULLEY CRANKSHAFT PULLEY PULLER IDLER PULLEY IDLER PULLEY - SUPERCHARGER POWER STEERING PUMP PULLEY PULLEY - ALTERNATOR PULLEY - IDLER PULLEY - WATER PUMP PULLEY A/C COMPRESSOR - BYPASS PULLEY CRANKSHAFT PULLEY/RIM - A/C CLUTCH SUPERCHARGER IDLER PULLEY Is there another name for it or is one of these the right one? |
can't remember exactly what they called it. Go to the store and have them look it up. I got mine at either Autozone or Advance Auto.
belt tentioner, get a delco replacment, not some cheep autozone one
Belt tensioner.
I agree get a GM tensioner. I got a auto parts store one and within about a month, it was squeeking again. Bought a GM one and never had that problem again for 40000 miles.
Gregg Schulz Wisconsin Rapids, WI 1996 Chevrolet Blazer LS 4DR 4.3L W V6 |
I've got 20k on my el cheapo replacement and not a squeak out of it
I had my check three years ago from a shoddy dealership,
It was squealing like crazy their first impression was the water pump was
bad I said NO, than they said I needed a new Alternator Generator I said NO, I asked them to tighten the tensioner belt and lube it. They refused to do any of the work, I reported them, after I went to my local mechanic and he said it just needed adjustments... He fixed it and it was gone.. Moral to the Story... The Squeaky Wheel doesn't always need to be replaced... |
no offence at all, but when we get costomers telling us what is wrong and what we have to do, we button it up, and shove it out the door, the alternater is a possibility for a squeek or howel, looking at the tentioner tells you if its good usually, if its the tentioner and not the pully, pullys usually dont go bad, so alternater is a good assumption, however it is an eazy job that takes an expencive part...
