Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-11-2006, 02:00 PM
fcburn44 fcburn44 is offline
Question green transmission fluid
i have a 94 intrepid with a 3.3 i just checked my tranny fluid and it looked green. is this normal??
Old 01-11-2006, 02:57 PM
WPAGEJR WPAGEJR is offline
Re: green transmission fluid
[quote=fcburn44]i have a 94 intrepid with a 3.3 i just checked my tranny fluid and it looked green. is this normal??[/QUOTE
NO I DONT THINK THAT IS NORMAL. SOUNDS LIKE YOUR RADIATOR IS LEAKING COOLANT INTO THE TRANMISSION COOLER.
Old 01-11-2006, 09:46 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
usually, coolant mixing with tranny fluid would be orange in color. Like was mentioned before, you probably need to replace your radiator and have a tranny flush.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 01-11-2006, 09:54 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I have green transmission fluid....
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-14-2006, 02:09 PM
AWP9521 AWP9521 is offline
Raptor Blood huh? If that stuff doesn't meet the Chrysler spec for ATF+3 or ATF+4 then I would stay away from putting that stuff in these transmissions, especially if they are talkiing Dexrom/Mercon compatible stuff. A firmer shift is just what those tranny's need, so the TCM will keep softening the shifts and wear the clutches out sooner.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 01-15-2006, 03:21 PM
Yeah, that stuff is a Dexron III replacement only. They do make a supplement compatible with all fluids called "Raptor Tamer"..
Old 01-16-2006, 10:12 PM
Dexron III is not compatible with Mopar ATF +3 or 4 fluid. It will give you problems, I guarantee you of that.
