Old 01-11-2006, 02:57 PM
sblkcamaro70 sblkcamaro70 is offline
zc question
what car came with the zc motor?
Old 01-11-2006, 04:03 PM
justin476 justin476 is offline
Re: zc question
the si's in japan came with the zc.
Old 01-11-2006, 04:13 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
The USDM D16A1 engine that came in the 86-89 Integra IS NOT a "ZC" engine. ZC is a name that honda attached high output versions of the D-series engines.
The ZC name is applied to many different engines. Unfortunately I cannot find a definitive list of EVERY type of ZC but the following information is pretty good and will expand our collective knowledge.
A few things we definitely know-
* The ZC came with carbs and fuel injection.
* The ZC came as a DOHC and a SOHC.
* The ZC is not CARB (California Air Resources Board) legal.
* The D16A1 in the USDM 1986-89 Integra is not a ZC, but has a similar block
* The DOHC ZC has two different major types, Early and Late
* The Early DOHC ZC had the Valve Cover bolts on the middle of the valve cover
* The Late DOHC ZC has the Valve cover bolts on the outside edge of the valve cover.
* The SOHC ZC and the Late DOHC ZC are related to the 1988+ D series engines.
The following is info I found on the web regarding ZC engines.
The ZC Engine
In Honda's line-up of engines, perhaps the one which leads to the greatest amount of confusion would be the ZC engine. This engine comes in a wide variety of forms. In this installment of topic of the moment, Temple of Vtec- Asia (TOV-A) looks at the various forms of the ZC engine. As usual, we try to be exhaustive in this examination but there is always the possibility we could have missed out on one or more items. Let us know if we have missed any out.
As far as TOV-A knows, the ZC engine comes with an engine block that has 4 cylinders, water-cooled, with bore and stroke as 75mm by 90mm, i.e. an under square design. Thus, the capacity of the ZC engine is always 1590cc. The ZC engine comes in various configurations, SOHC, DOHC, carbureted as well as fuel-injected. The only configuration that ZC does not come in is in DOHC-VTEC form. The ZC engine is also used in a large variety of models. The list below tries to tie the various configuration of the ZC engine to examples of Honda models and types that they appear in. This list is not intended to be exhaustive.
SOHC twin-carbureted
16V SOHC, with dual Keihin carbs mounted side-ways.
Max Power : 105ps.
DA-series Honda Integra RX and ZX.
DC-series Honda Integra ZX.
EG-series Honda Ferio RTX (EH1) with 'realtime' 4WD.
SOHC PGM-Fi
16V SOHC, Programmed Fuel Injection.
Max Power : 120ps.
EF-series Honda Civic 36i (4door).
DA-series Honda Integra RXi and ZXi.
DB/DC-series Honda Integra ZXi.
Revised DB/DC-series Honda Integra, various models, eg Ti, Xi-G, Xi(4WD).
SOHC VTEC PGM-Fi
16V SOHC with VTEC, Programmed Fuel Injection.
Max Power : 130ps.
EG-series Honda Civic Ferio EXi (coded as E-EJ3).
DOHC PGM-Fi (First generation)
16V DOHC, Programmed Fuel Injection.
Max Power : 125ps.
1st Generation Honda Civic Si.
1st Generation Honda (coded as E-AS) CRX Si.
1st generation Honda 'Quint' Integra GSi and RSi.
DOHC PGM-Fi (Second generation)
Max Power : 130ps.
EF-series Honda Civic (4door and 3door) Si.
EF-series Honda CRX Si (EF7).
EG-series Honda Civic Ferio RTSi (EH1) with 'realtime' 4WD.
The ZC engine also appears in other Honda lines, notably in SOHC PGM-Fi and SOHC Dual-Carb'ed form in the Concerto line-up which was also available for export (Singapore is one country which has this model in its domestic lineup).
Of note is the 1.6l SOHC VTEC PGM-Fi engine as used in the JDM Honda Civic Coupe and various current generation EK-series Civic types although having the same capacity (1590cc) with same bore and stroke is coded D16A instead of ZC. In fact, the EJ1 JDM Civic Coupes have plates that state they're manufactured in the United States.
The same configuration of engine, with matching power output levels, (120ps at the same rpm), is also available in what can best be described as 'lesser' markets for Honda. This engine then often powers the top models for that market. An example is the Malaysian domestic line-up, which for the previous and current generation has a Honda Civic 1.6EXi which is powered by a 120ps 1.6l SOHC PGM-Fi engine but coded as SM16A. Similary, for the equivalent EF-generation, the Malaysian domestic line-up has a top model, the Honda Civic 1.6EX which is powered by a 105ps 1.6l SOHC Dual-Carb'ed engine coded as D16Z1. There is a distinct possibility that these engines are localised export versions of the 'master' JDM ZC engine.
One interesting item that TOV-A has come across is a ZC engine that is DOHC but uses dual-carburetors. The owner whom contacted us to find out more about the engine says that it came off an older JDM Integra. Unfortunately, TOV-A is not aware that such a configuration of the ZC engine even exists! If any of you have any additional data on this engine, please let us know.
Temple of VTEC - Asia. June 03 1998
Source : Official JDM Honda Integra Catalog 1989-1991
3-door Coupe 4-door sedan
Model Integra RXi/ZXi Integra RSi/XSi Integra RX/ZX/
ZX-extra Integra RXi/ZXi Integra XSi
Code DA5 DA6 DA7 DA8
Engine ZC PGM-Fi B16A ZC carb ZC PGM-Fi B16A
Length(mm) 4390 4480
Width(mm) 1695
Height(mm) 1325 1340
Wheelbase(mm) 2550 2600
Clearance(mm) 150
Weight(kg) 1040-1110 1060-1170 1030-1100 1060-1130 1120-1190
Tyre Size 185/65R14
85H 195/60R14
85H 185/70R13
85S 155/65R14
85H 195/60R14
85H
Engine Line-up 1989 to 1991
Engine ZC carb ZC PGM-Fi B16A
Capacity(cc) 1590 1595
Bore X Stroke(mm) 75.0 X 90.0 81.0 X 77.4
CR 9.1 10.2
Specification 16V SOHC dual Keihin carbs 16V SOHC PGM-Fi 16V DOHC VTEC PGM-Fi
Max Power(ps/rpm)
manual/(auto) 105/6300 120/6300 160/7600
(150/7100)
Max Torque(kgm/rpm)
manual/(auto) 13.8/4500 14.5/5500 15.5/7000
(15.3/6000)
1st Gear MT/AT 3.250/2.705 3.250/2.647
2nd Gear MT/AT 1.894/1.560 2.052/1.566
3rd Gear MT/AT 1.259/1.027 1.416/1.111
4th Gear MT/AT 0.937/0.780 1.103/0.810
5th Gear MT/AT 0.771/- 0.906/-
Reverse Gear MT/AT 3.153/1.954 3.000/1.904
Final Drive MT/AT 4.250/3.933 4.437/3.933 4.400/4.428
Model Line-up 1991 to 1993
Source : Hyper-Rev Vol27 'Integra'
Note that this is not an official Honda source so the data here will not be authoritative
Model Integra ZX Integra Zxi Integra RSi/XSi Integra ZX-extra Integra ZXi Integra ESi Integra XSi
Code DA5 DA6 DA7 DB1 DA8
Engine ZC carb ZC PGM-Fi B16A ZC carb ZC PGM-Fi B18B B16A
Width(mm) 1695
Clearance(mm) 150
Weight(kg) 1030-1050 1060-1080 1060-1130 1030-1050 1070-1090 1130 1130-1150
Tyre Size 185/70R13
85S 185/65R14
85H 195/60R14
85H 185/70R13
85S 185/65R14
85H 195/60R14
85H
Note : Same caution applies as for Model Line-up
Engine ZC carb ZC PGM-Fi B18B B16A
Capacity(cc) 1590 1834 1595
Bore X Stroke(mm) 75.0 X 90.0 81.0 X 89.0 81.0 X 77.4
CR 9.1 9.2 10.4
Specification 16V SOHC dual Keihin carbs 16V SOHC PGM-Fi 16V DOHC PGM-Fi 16V DOHC VTEC PGM-Fi
Max Power(ps/rpm)
manual/(auto) 105/6300 120/6300 140/6300 170/7800
(155/7300)
Max Torque(kgm/rpm)
manual/(auto) 13.8/4500 14.5/5500 17.4/5000 16.0/7300
(15.6/6500)
1st Gear MT/AT 3.250/2.722 -/2.647 3.230/2.647
2nd Gear MT/AT 1.894/1.555 -/1.483 2.105/1.566
3rd Gear MT/AT 1.259/1.027 -/0.974 1.458/1.111
4th Gear MT/AT 0.937/0.780 -/0.725 1.107/0.810
5th Gear MT/AT 0.771/- -/- 0.848/-
Reverse Gear MT/AT 3.153/1.954 -/1.904 3.000/1.904
Final Drive MT/AT 4.250/3.937 4.437/3.937 -/4.428 4.400/4.428
November 1999
WongKN
Source : Official Honda JDM catalog and Hyper-Rev Vol27 'Integra'
1G ZC "Brown Top" D16A3
Engine ID: ZC
CC: 1590
Hp: 135@
TQ: 112@
Bore: 75mm
Stroke: 90mm
Compression:
Fuel System: PGM-FI
Ignition System: Vacuum Advance
Notes: Valve Cover Bolts are in the middle of the valve cover, NOT USDM LEGAL
86-87 US Integra "Brown Top"
Engine ID: D16A1
CC: 1590
Hp: 113@6250rpm
TQ: 99@5500rpm
Bore: 75mm
Stroke: 90mm
Compression: 9.3:1
Fuel System: PGM-FI
88-89 US Integra "Black Top"
Engine ID: D16A1
CC: 1590
Hp: 118@6500rpm
TQ: 103@5500rpm
Bore: 75mm
Stroke: 90mm
Compression: 9.5:1
Fuel System: PGM-FI
Ignition System: Electronic Advance
2G ZC "Black Top" (this engine DOES NOT attach to the 86-89 Integra transmission and is closely related to the 1988+ D series engines)
Engine ID: ZC D16A8 (no catalytic converter), D16A9 (catalytic converter)
CC: 1590
Hp: (130 I'm not sure)
TQ: (I don't know)
Bore: (75mm I think)
Stroke: (90mm IIRC)
CompressionI don't know)
Fuel System: PGM-FI
Notes: Valve Cover Bolts are on the outer sides of the valve cover, NOT USDM LEGAL.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-12-2006, 12:45 AM
so which zc is the easiest to swap in a stock 89 civic with the dpfi? i am assuming all zc's bolt up to d series trannies
