Old 01-11-2006, 12:52 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Which sensor is this again?
I know it's been a while since I've posted, but for those of you who know me, you know why.
I've wanted to get the CRX back in shape and there are a few things I need to do and the one of them is to replace the sensor that makes the idle go all crazy up down up down you know the deal. Instead of me scratching my head for hours, I'm sure someone can spit this out pretty quick.
Thanks!
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 01-11-2006, 01:35 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Which sensor is this again?
its called an idle air control valve....or IACV....it has two little coolant passages, a solenoid, a big plastic screw and a port for ambient air to pass through.....
ON the top of the mani of this pic
or at the top of the pic on this...the black solenoid
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-11-2006, 02:25 PM
quiXilver's Avatar
B18A
Old 01-11-2006, 02:33 PM
96 civicturbo 96 civicturbo is offline
Send a message via MSN to 96 civicturbo
What The Idle Air Control Valve
Old 01-11-2006, 03:03 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Also known as EACV - Electronic Air Control Valve...
not to hijack, but I was wondering someone a long time ago either bambam or 91civicdxdude said that you can remove the FITV (Fast Idle Throttle Valve) cuz you really don't need it. My fan stays on with ignition so I've been wondering about it. Think its below on the right side of IM...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-11-2006, 08:41 PM
Hybrid1990crx's Avatar
Most people call it the IAC valve, pronouncing the I-ACK.
anyway, yes that is it in the picture you posted quixilver.
turtle, do you have your fan wired to run at all times, or is it a wiring problem? probably something youd what to look at rather than removing the FITV, it could cause hard starting if the fuel mixture is incorrect in cold temperatures.
Old 01-11-2006, 10:11 PM
quiXilver's Avatar
I was wondering where I could get that IAC. Anyone know where I can get one for my b18a?
B18A
Old 01-11-2006, 11:13 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
ebay.com
honda-tech.com classifieds
your local parts store.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-11-2006, 11:27 PM
quiXilver's Avatar
the parts store wanted 190 frickin' dollars for it.
on ebay they don't specify what it's for, are they all the same for the same year? or differ between motors?
B18A
Old 01-12-2006, 12:30 AM
go to www.discoveryautoparts.com. they should have it cheap there. good luck bud
Old 01-12-2006, 01:16 AM
i say check on honda-tech, im sure there is someone selling one.
Old 01-12-2006, 07:24 AM
Re: Re: Which sensor is this again?
It's a botched relay but still works through harness so I left it and wired the fan to stay on with ignition. I'm just going to leave it as is...
2010 Honda CR-V EX
Old 01-12-2006, 08:02 AM
quiXilver's Avatar
thanks guys
B18A
