Go Back   Automotive Forums Car Chat > Cars in General
Old 01-11-2006, 11:36 AM
recon_element recon_element is offline
Adding a Spray Coating to Dash Pad - 93 Lumina
Hi.
I recently purchased a 1993 Lumina, and want to replace the main dash pad because of discoloration and warping. Finding one shouldn't be a problem, but once I find one in good condition, I want to make sure that the same damage does not occur with the new dash pad.
Normally if this piece was hard plastic I would most likely go through the normal procedure of painting, but it's actually made of a wierd spongy material, and I'm thinking that some sort of spray-on hard coating would prevent any damage in the future.
Any recommendations on what I should use and where I might find it?
Keep in mind this is a low-budget project.
Thanks.
[email protected]
Old 02-23-2006, 08:39 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
Re: Adding a Spray Coating to Dash Pad - 93 Lumina
It's soft for a reason, in order to cushion in case your head hit's it in a car accident. I wouldn't reccomend stiffening it up. see if you can glues the original one back down.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
