1998 Blazer fuel pump stopped
I've viewed this forum often and gained valuable insite. Thanks to those that respond. I've searched and can't find a problem that is like mine, so here it is.
Drove my Blazer to work and then to lunch without any problems. When I was going to go home all systems seem to be working, starter, lights etc. The starter turned the engine without starting. After a couple of tries I noticed that the familiar buzzing from the fuel pump when you turn the key to "on" was missing. From noon until 4PM something broke while the car was sitting. Any thoughts? |
Re: 1998 Blazer fuel pump stopped
One very common problem with electric fuel pumps falling all of a sudden
is, a dead spot on the armature of the pump motor. Some times you can bump it and it will work again for a while. Until it shots on the dead spot again. Check the relay like family mechanic said. If the relay is working,check for voltage at the connector on the top of your tank. These fuel pumps aren't very cheap, so you want to make sure it is the fuel pump for sure. Check to see if you have fuel in the little valve fitting under your hood. Post back with the info please. Thanks SC |
Re: Re: 1998 Blazer fuel pump stopped
Had same problem on my 98 blazer pulled into a store was running fine went out 15 minutes later wouldnt start tested pressure none from fuel pump be careful though chevrolet put 3 different fuel pumps in the 98
i took awhile to figure out but the difference is in where the seal is the rest of the pump looks the same i replaced mine and it is working fine good luck buy the way the pump is $300.00 |
Wow 300.00 mine was 84 bucks out the door. going rate in ohio.
prices are great in ohio dealer here wanted $600.00
BTW, Fam_Mechanic, if I do need a fuel pump, where did you get the $84 dollar one? I checked around here (Cincinnati area) and it's in the $260 range. |
Re: Re: Re: 1998 Blazer fuel pump stopped
1.)You can buy just the pump if you know the part number, from any GM dealer (~$100.00) you can look this up at www.gmpartsdirect.com 2.)You can buy the complete fuel pump assembly from most parts stores for ~$300.00. this includes the housing 2 strainer socks,and the float level sensor. 3.) you can buy this same assembly from any GM dealer for ~$450.00. The best way to go (in my opinion) is to buy the assembly from Napa,Autozone, etc, because you get a new housing. The old housings have a tendency to crack or break during the retrofit, plus you get a new gasket.
It's my opinion, don't take it personal. '04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC |
First make sure that your battery is FULLY charged! Then attemp to start the vehicle using short bursts of the key (about 2 to 2.5 sec.). if after about 6 to 7 tries you hear the engine attempt top start, the your fuel pump is gone. I drove my ,96 arounf like that for a month. The short cranks allows the pump to build up enough pressure to allow the engine to start. This of coarse assume that there is still electrical continuity going through the pump and the volume is just not enough to start the vehicle. Get a fuel gauge and check the pressure. That will of coarse answer your question. |
Had an opportunity to begin troubleshooting today.
1. Swapped relays in the under the hood fuse box - negative results. 2. Located a relay mounted on the passenger side firewall - Should I replace as a test? Is there a jumper test? 3. Can't find the red wire connector on the drivers side wheel well mentioned earlier. This one seems to be the definitive test. Hit it with a hot wire and see if the pump runs. If this is in error, is there another test lead? 4. Looked under the rear of the car and the leads to the fuel pump don't look accessible as well as being able to rap on the pump for a test. Did I overlook something? I'm not opposed to dropping the fuel tank but don't want to unnecessarily. |
Re: Re: Re: Re: 1998 Blazer fuel pump stopped
The red test lead for the fuel pump should be close to the firewall on the driver side fender wall. It will have a insulated fast-on (.250 wide) connector on the end. It should be sticking out of the harness bundle all by itself. (may appear to be orange) edit; The wire harness to the pump is on the top of the tank. You have to drop the tank to get at them (you also need a long arm). Be very carefull doing this, as the wire leads are short, and you need to support the tank as you lower it. It rather tricky getting at them without breaking plastic parts of the pump housing off. You can't rap on the pump because it's inside the tank.
