Go Back   Automotive Forums Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-11-2006, 07:11 AM
cutter9512 cutter9512 is offline
Using 100 LL as additive to XJR
I am new to this forum. I have owned a 1999 XJR. It has run flawlessly over the last 6 years and 70,000 Miles. I have access to AV GAS. I wonder whether the onboard computer will advance the timing with the increase of octane associated with addition of 100LL (as a mix)? Will this destroy the converter? Or will the addition of enhanced octane, increase the power of the motor?
Old 08-25-2006, 08:06 AM
mishalah's Avatar
mishalah mishalah is offline
Re: Using 100 LL as additive to XJR
If you haven't....DON'T. There is no reason to use any fuel other than what is recommended. Your computer will go nuts trying to adjust timing, etc. I realize this is an old post, but I see this question a lot. Modern engine management systems will just compensate when the fuel gets out of normal ranges. I mix 100 (unleaded and 91 in my '91 ZR-1 Corvette because the 91 we get is well below the minimum 93 that was available when the car was built. The 100-105 Avgas did great in my modified '65 coupe years ago, but that was purely carb/water injection...and no electronics other than MDS spark. 93 octane should be plenty for the XJR unless you plan on racing it at the strip (which will kill your drivetrain).
Old 06-17-2008, 09:10 AM
danielsatur danielsatur is offline
I would spend your money on a Throttle body cleaning + MAF,you
will find any lost HP!
MCGIVER
Old 06-17-2008, 09:22 AM
BNaylor's Avatar
BNaylor BNaylor is offline
MCGIVER
Sorry but please check the date and do not resurrect old threads. This one is too old to be replying in. Your future cooperation is appreciated. This thread is closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
