Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-11-2006, 04:38 AM
edmswiz edmswiz is offline
Unhappy 92 Tbird Won't Start
I have bought a 92 Tbird LX w/ 5.0 engne for my son. It has been running great then it started acting like it had no power and when he pulled it to the side of the road it died and has refused to start. I have checked the fuel (getting fuel to the runners on the engine) spark (getting spark to the plugs). What is suspect is the injectors may not be firing. Any ideas on testing or other areas to look?
Old 01-11-2006, 12:27 PM
overl0rd overl0rd is offline
Re: 92 Tbird Won't Start
Did you check fuel pressure? Sometimes you will still get fuel to the rails but not at the required pressure due to bad pump, regulator, or plugged filter.
Old 01-11-2006, 05:26 PM
Re: Re: 92 Tbird Won't Start
How do you check the pressure? I see an fitting on the fuel rail that looks like a pressure gauge can be hooked to it. Is there a pressure guage that you can buy at the auto parts store?
Old 01-11-2006, 05:33 PM
Yes, you just hook it up the fitting with the schrader valve in it, and turn the ignition on. You can buy one or borrow one from autozone. Key on engine off pressure should be 35-40 PSI.
Old 01-11-2006, 10:28 PM
forcfed93's Avatar
forcfed93 forcfed93 is offline
I had a simular problem last spring .... I had moisture in the fuel.
Michael Albee - Prez
Super Coupe Club of IOWA
http://www.sccoia.org
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
1993 Mark VIII (a.k.a. "The Winter Beater")
Old 01-12-2006, 10:08 PM
I checked the pressure and it is about 40psi when cranking the engine. I also removed one of the plugs and cranked the engine to check the amount of spark and it seemed to working as expected. Is there a way to check if the injectors are firing. My only other thought is the timimg chain if that isn't it. Any ideas?
Old 01-12-2006, 10:45 PM
You can hook a noid light to the injector plug to see if its getting juice to ire the injector. Also check voltage from the throttle position sensor. If the PCM doesnt get signal from it the car won't run.
Old 01-12-2006, 10:50 PM
Something else just occured to me, make sure all your grounds are good. Make sure no ground straps are rusted or corroded through.
Old 01-14-2006, 10:42 AM
I checked and the injectors are getting voltage. I also checked the throttle position sensor with an ohmeter and it seemed to be working fine. I have also replaced the battery and replaced the spark plugs thinking a voltage or firing issue with no luck. The engine cranks but does not try to start and the started winds out of juice very quickly even with a new battery. Another other ideas?
Old 01-14-2006, 12:48 PM
97Bird's Avatar
97Bird 97Bird is offline
Check for codes. Do a compression test. You can see if there is slop in the timing chain by using a socket and breaker bar on the harmonic balancer bolt and rocking it back and forth.
The Original 97Bird
Old 01-14-2006, 05:33 PM
forcfed93's Avatar
Does it even pop? (any fire at all). Are the plugs fouling out?
If they are fouled, try to light the tip of the plug with a lighter or match. If it doesn't burn, drain the gas out of the car and put in some fresh gas. This happend to me a year ago and i drained the tank and put in fresh gas and it started right up. It took about 10 miles to clean up the idle, but I haven't had any more trouble.
The only other things I can think of are Crank Sensor and Cam Sensor.
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
