Old 01-11-2006, 01:06 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Arrow Update: Popping, Oil Filter, and Stuff
Hey all;
Just alittle update on my car with some problems I had earlier.
1) Last time I changed my oil, I posted that I couldn't get the oil filter off. I ended up denting it, and pretty much said 'screw it, ill do it next time.' I checked out the filter the next week, and it had expanded back to its original shape. I've notice little oil spots where I park in my driveway and at work, and decided to have a looksee under the car. Oil all over. I look at the filter, and where it had dented and popped back out, was a hole. A small one, but enough to drip.
So, I drained it and tried the filter. Again, it failed and only dented. I took a screw driver to it, broke it though, still nothing. I just made a bigger hole when trying to turn it. In the end, it took 2 hours to get off, but I did with the screw driver. So far, no drip, but I have to wait till the morning.
2) I posted awhile back about a popping noise from the block when I shut off the engine. Apparently, the oil filter had something to do with it because it gone.
So the moral is... change the oil filter. Don't damage it, then decide not to take it off. I'm lucky bc the hole was small and I didn't lose that much oil. That could have been fatal to the engine.
Tomorrow (if weather permits) Im going to install my SAFC. Got everything all set to go for the install. So wish me luck.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-11-2006, 01:46 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Glad your screw up didn't cost you your engine. Have fun with the install.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-11-2006, 06:45 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Update: Popping, Oil Filter, and Stuff
I love to tinker with my car. So I am over-joyed to hop under the hood and fill and fix things sometimes.
....It has been a LONG time...I want to move to FL or Japan.....
Old 01-11-2006, 07:54 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
What brand filter did you use?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 01-11-2006, 09:24 AM
inatalonIXLR8 inatalonIXLR8 is offline
You may already know this trick, but smearing a little oil on the O-ring seal on the filter before you fill it full of oil and put it on will help it not to seize next time.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-11-2006, 09:37 AM
david-b's Avatar
Dave is THAT guy
I know that, and did it. The new one here I put alot of oil on the o-ring.
The one that got stuck was a STP. I usually use Bosch (like the new one), but I got it for free after rebates or something like that. I'm not one to be picky about the filters.
75 Monte Carlo
Old 01-11-2006, 10:11 AM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Take note that when the surface of the 0-ring on the filter touch the opposing surface, then turn it 3/4 more...Also I decided to change my moms oil filter on her 03 expedition...took me 5 HOURS! The oil filter is not in a nice place like our 420A and it was seized like a bitch.
Old 01-11-2006, 10:41 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
i get seized oil filters come into my work from valveoline they must torque theirs to 200ftbls! lol you kno what i mean
Old 01-11-2006, 12:55 PM
Gsx_hooptie Gsx_hooptie is offline
Make sure you use new oil when you put it on the seal. Kind of obvious, I know.
The screwdriver usually works for removal when all else fails.
I used a 12" 3/8ths extension once (slid it through the screwdriver's punched hole) when the screwdriver didn't provide enough mechanical advantage for my girls arms. That was messy.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 01-11-2006, 02:04 PM
david-b's Avatar
Dave is THAT guy
^^^ Nice. I never thought of doing that. Good idea.
75 Monte Carlo
