Old 01-10-2006, 10:42 PM
88CRX-V-TEC 88CRX-V-TEC is offline
Send a message via Yahoo to 88CRX-V-TEC
1999 V-Tec B16 Ob1 computer setup.
what kinda issues will i have with a OB1 Computer or the Ob2 computer ??
Old 01-10-2006, 11:25 PM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
Re: 1999 V-Tec B16 Ob1 computer setup.
99 is OBDII, OBDI was pre-96 (except in California, where II started in 95). the newer you get, the more its gonna be controlled/regulated by the computer/ecu, which can cause problems if you plan on doing any tuning (especially if you are in a state that has an emissions test). personally i'd go for OBD0 or OBD1, although i think i heard something about vtec being stronger with I or II as opposed to 0 or I...
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 01-11-2006, 10:18 AM
96 civicturbo 96 civicturbo is offline
Send a message via MSN to 96 civicturbo
If you swicth to obd1. You can do a hell of alot more to you car. esp if you are going to do a turbo or supercharger. obd1 you can elimanate o2 sensors, cat, ex. And it is a lot easier to fine tune it. My body has a built 99si from bottom up. It was built by vortec. The put the vortec supercharger on it. It dyno at 386whp. He swicth to obd1, remove 02 sensors, cat, and put a staight 3' exshaust on it. He took the charger off, and turbo it at 25 psi, and obd1. he has 562whp. But if you have a emissions test you really can't pass it if you go to obd1
