Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 01-10-2006, 11:38 PM
kali420 kali420 is offline
help just purchased 90' 300zx need alt rebuilt and has oil leak
ok as alt goes thats just my time and 60 bones but this oil leak!! it only leaks while running but a fair amount the guy i bought it from didn't know much and said it was just a oil pan leak but at first look i knew it was more than that. so i was told that oil persure sensor is prone to leak. leak looks to becoming from front of engine but oil is every where. this is my first 300zx and i know that this leak could be much worse than i figured but was a good price and do all my own work so any help would be great
Thanks, Joe
Old 01-11-2006, 04:37 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Is there any clicking sounds or other noises coming from the front of the engine? The VTC gears (intake cam gears) run on oil pressure and might be the cause. Other wise it would most likely be valve cover gaskets or the oil pan seal.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 01-11-2006, 01:03 PM
no noises runs great but to much oil for valve cover or oil pan
only leaks while running does. any one know where the oil presure sensor is? I have bought a service manual yet. and if it was The VTC gears (intake cam gears) what need to be replaced?
thanks agian
Old 01-14-2006, 12:10 PM
jam88300zx jam88300zx is offline
Re: no noises runs great but to much oil for valve cover or oil pan
I use to own a 88 300zx with 168K, and the oil leaked from the crankshaft area and would leak only when the engine was running. Turned out that it was leaking from the front main seal, took it to a shop that replace the seal, timing belt, water pump, tensioner for about 700 bux.
