Old 01-10-2006, 09:39 PM
larobley larobley is offline
2003 wont start
I have a 2003 and it died while driving. and the low trac loght came on. It gets fuel to the relief valve by the injectors. I tryed to get the OBII codes but all it says is pass no codes. Any Ideas of what to do next.
Old 01-10-2006, 09:45 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2003 wont start
Got spark?
Got fuel pressure?
Got injector pulse?
MT
MT
Old 01-10-2006, 10:01 PM
I know that fuel gets to the injector rail were the relief valve. Not sure how to check injector pulse?
Old 01-10-2006, 10:31 PM
MT-2500's Avatar
AF - Advisor
Re: 2003 wont start
You also need fuel pressure there.
Like 59/60 lbs on key or key on eng cranking
How much fuel pressure have you got?
Have you got good hot spark at 2 or more plugs?
What engine and trans and what mileage?
MT
MT
Old 01-10-2006, 11:34 PM
swingline swingline is offline
Re: 2003 wont start
it sounds like a computer problem to me. if the low traction light came on i would guess that a speed sensor went haywire, and maybe the computer shut off the fuel, the caveliers powertrain control modules are mouted in the right front wheel well and have a tendency to odd problems due to moisture/ corrosion.
Old 01-20-2006, 07:28 PM
Thumbs up Re: 2003 wont start
Well It ended up being the Fuelpump they said there was some unknown guey stuff in the tank.....Thanks everyone for your help
