Old 01-10-2006, 07:09 PM
b00stedspYder b00stedspYder is offline
where is this boost leak??
OK ive found another boost leak...but i have no idea where its coming from! there is a lot of air flow coming from under the throttle body...or it seems that way... as i pressure test it the air only leaks from somewhere under there...i replaced the gaskets and sealed them around the TB and that still did nothing. Does anyone know where its coming from or have an idea so i can check this out...my boost gauge hold at about 8 psi..this leak is killing me. Where could it be?? Thanks!
Old 01-10-2006, 08:22 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: where is this boost leak??
It could be the throttle plate shaft seal there is a how to on vfaq.com. Hopefully thats it, if they have never been replaced then thats probably it.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-10-2006, 09:06 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Check to make sure you have a good seal on the i/c piping?
1991 GSX 2.3 Stroker
Old 01-11-2006, 09:43 PM
ok i tested the thing all day today at work...the vfaq said to leak test it and have bud press the gas to see if the air would come out in a different place or sound a lil different...i did this and it did nothing...there was no change with throttle or without...so im thinking its not the plate shaft seals...could it still do this if the 0-rings are bad??
this is killing my feeling all the air leak and i cannot find the damn leak!
Old 01-11-2006, 10:04 PM
ez1286's Avatar
I guess it could still be the o-rings. How bad of a leak it it? Cause I don't think they generally leak all that bad. It could be your egr valve seal. When I blocked mine the first time it caused a boost leak.
Old 01-12-2006, 07:17 AM
i mean its not the worst leak ever...but its a pretty good size leak...theres quite a bit of air flowing out somewhere...i can def. tell while driving...what do you mean u blocked it. what did u block??
Old 01-12-2006, 09:41 AM
kjewer1 kjewer1 is offline
AF - Advisor
It could be a number of things, but the first thing that comes to mind in that area that makes a leak big enough to feel easily is the TB elbow. Not sure which one you are using or if it is stock, but most of the aftermarket ones are warped. No amount of sealant can fix them. I fought this for over a year until I got off my ass and took it to my machinist to get it planed.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-13-2006, 06:03 PM
i dont have an elbow...i have all hard IC pipes upper and lower...its not leaking from the ic pipe...im sure of that...it seems like its coming from under the throttle body somewhere but i cannot tell where...
Old 01-13-2006, 06:26 PM
defiancy's Avatar
Re: Re: where is this boost leak??
Intake manifold?
Old 01-14-2006, 01:54 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Re: Re: Re: where is this boost leak??
Originally Posted by defiancy
Intake manifold?
Yeah, there's a metal gasket between the tb and the manifold. If you reused it after taking the tb off or put in on backwards mabe that could cause it? But you said you replaced the gaskets.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 01-14-2006, 09:46 PM
AF - Advisor
"Elbow" is just terminology. Where the hard pipe mates to the TB could also be warped. I've had pipes like this. I really wish people could look for the essence of my posts and apply the theory, not just compute the exct words. It would make a lot less work for me over the years
Get a flashlight and a mirror, and start spraying some soapy water in there while you test. I've never met a leak I couldn't find in the last 5 years.
Kevin Jewer
Old 01-15-2006, 11:12 AM
okthanks GSX...i know the stock pipes on dsms have that elbow to the tb i thought u meant that...ok ill give the soapy water a try today and see how that goes over..thanks again
Old 01-15-2006, 01:32 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
http://store.yahoo.com/machv/throtbodseal.html
There's a link to some awesome TB shaft seals....
Otherwise I have heard of the bottom side of the int. manifold having leaks where there is a bolt that goes into it and has been known to leak... bitch to get to but just something to look into....
Soapy water is one of the greatest tricks.....it's application is used for soooooo many things!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
