Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 01-10-2006, 07:15 PM   #1
anthony303
Unhappy 98 s-10 looking for lower intake r and r schematics
losing coolant in my 98 s-10 4.3 vortec engine and no coolant loss on ground someone said it maybe coming from lower intake i took a look and i see moisture around gasket and some of the bolts i see coolant which has dried,what i'm looking for is a print out step by step on how to replace gaskets,i bought a felpro set and i'm ready this weekend to do this,i need torque specs and any tricks to doing this job would be helpful thanks anthony303
anthony303 is offline   Reply With Quote
Old 01-10-2006, 07:48 PM   #2
dmbrisket 51
dmbrisket 51's Avatar
Send a message via AIM to dmbrisket 51
Re: 98 s-10 looking for lower intake r and r schematics
trick 1: throw that felpro shit away, because the gaskets are no longer plastic, they are aluminum
trick 2; a factory service manual is the only thing as detailed as what your asking for, you have to peel the wiring harness out of the way, remove the plastic plenum, then the lower intake, clean it up good, and put the GM gaskets and bubble back on... sorry if i sound like a jerk, dont mean to sound that way, this is a serious job, we do several a week, and it takes me and my cousin up to 8 full hours, 2 licenced machanics in the best of atmospheres, a long ass time (some of our time comes in the fact our work is warrentied, and we can miss NOTHING on tear down or build up) for any job, but if you mess up it realy screws the hootch.
dmbrisket 51 is offline   Reply With Quote
Old 01-20-2006, 04:39 PM   #3
Mikebox
I just did this on my 97 s10 4x4. It took about 6 hrs including the drain/refill of the coolant.
I did use the felpro set; decent stuff and has been fine for about 2000 miles so far.
Remove all the heater hose connections to the lower intake,
remove all of the sensor wires and move them aside. I like to mark each one with numbered tape or colored tape; however, they are each unique so you could skip that step. De-pressurize the fuel system and disconnect the lines near the firewall. You DO NOT have to remove the upper intake from the lower to remove the unit.
Unbolt the lower intake and remove carefully. Clean all the gasket surfaces (make sure you cover the lifter valley while doing this so that gasket crap doesnt fall into the crankcase. Assemble the gaskets to the heads, put black RTV on the front and rear block lips then install the manifold assy. Use thread sealer on the bolts. Torque to spec and reconnect all of the hoses/lines/wires in reverse order.
I would and did change the oil as mine was leaking internally and I wanted to make sure that no small particles were left behind.
Refill with coolant and test drive. Good luck if you havent already done this.
Mikebox is offline   Reply With Quote
Old 05-19-2006, 11:44 AM   #4
pkcorvette
What is meant by the statement "you DO NOT have to remove the upper intake from the lower to remove the unit"? I've just started this job and I'm wondering if I need to remove the upper intake plenum. If not, do most people do this to replace the upper gasket?
pkcorvette is offline   Reply With Quote
Old 05-19-2006, 05:38 PM   #5
dmbrisket 51
the plastic bubble doesn't need to come off
Old 05-19-2006, 07:18 PM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Lightbulb Re: 98 s-10 looking for lower intake r and r schematics
Drop up in the blazer forum. I think there is several how to post on lower intakes with pictures on it.
Good Luck MT
MT
MT-2500 is offline   Reply With Quote
Old 09-05-2006, 07:34 AM   #7
v6stang108
Thats odd I had to take the plenum (upper intake) off to get to five bolts that hold the lower intake to the heads. It took me about 6 hrs aswell to do the job. First time too.
v6stang108 is offline   Reply With Quote
