Old 01-10-2006, 05:24 PM
tsiskeetskeet tsiskeetskeet is offline
gauge lights out, radio not working
I was putting a head-unit in my talon and the gauge lights stopped working, and the radio doesn't work. I replaced the radio fuse from the fuse box located the hood and nothing has changed. Has anyone had this problem or know how to fix it. Thanks.
Old 01-10-2006, 05:37 PM
WrecklessMM's Avatar
WrecklessMM WrecklessMM is offline
Re: gauge lights out, radio not working
recheck for blow fuses. try disconnecting the head unit and fuses and see you have ur gauges back. then you know your wirings bad somewhere.
Old 01-10-2006, 06:49 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Your inside lights, radio, and back lights will all be out. It's all on one fuse. Some radios (when hooked up to the default wiring) will keep causing this fuse to blow. You may have to wire it somewhere else then.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
