Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 01-10-2006, 04:27 PM
Evan_33 Evan_33 is offline
Question Flywheel compatibility
I am currently swapping transmissions and need to know if the flywheel from a 2.5L 4cyl will fit the 2.8L v6?
Old 01-11-2006, 09:09 AM
MrPbody MrPbody is offline
AF -Advisor
Re: Flywheel compatibility
Evan,
Yes and no. That is, it will bolt up, but... What year is the 2.8?
'87-older 2.8s are "externally balanced". What this means to you, is the flywheel (manual trans) or flexplate (auto trans) has weight "added" or removed, to bring the engine into balance. '88-newer 2.8s are "internally" balanced, so the 4 cylinder unit will be fine.
Replacements are readily available.
Jim
