Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 01-10-2006, 02:58 PM
sethramesh sethramesh is offline
Changing Brake pad
Hi
I am planning to change my 1998 Civic DX front pads/Discs. How difficult this work is? Any special tool to remove the caliper?
Appreciate your tips
Thanks
Old 01-10-2006, 03:15 PM
cas4067 cas4067 is offline
Re: Changing Brake pad
Originally Posted by sethramesh
Hi
Thanks
It is not that difficult at all.. Just remember what pad goes on each side of the caliper... As for removing the caliper I took it off a while back I dont remember using any special tool, might have used a star or square bit. Not positive on that, but it also came off purty easy...
check it out let me know what you think
my ride
Old 01-10-2006, 03:28 PM
96 civicturbo 96 civicturbo is offline
Send a message via MSN to 96 civicturbo
you will need a 12mm wrench or socket to remove the caliper, and a 14mm for the caliper hanger. if there are screws holding on the rotor, you will need an impact screw driver. You can get them any were. Part store, sears, home depow. And the rotor will fall right off. You might have to bang the rotor a little bit with a hammer.
Old 01-10-2006, 03:48 PM
oh by the way make sure you do not stip the screw holding in the rotor.. Did it one time and it was no fun at all...
my ride
Old 01-10-2006, 05:46 PM
if you do strip the screw, You really dont need to put them back on either
Old 01-11-2006, 12:31 AM
rushb18 rushb18 is offline
Be sure to push the caliper piston back in to if not the caliper will not go over the new pads if your old ones was wore down alot...
2 bolts on the backside of the rotor to take caliper off like was said its a 12 MM..Thats about it...
