Old 01-10-2006, 12:23 PM
Partha Partha is offline
Driver's Info center displays nothing
Hi guys,
Its been two days.. my D.I.C is all blank.
However the eng/met , reset, mode and the trac buttons are working (i mean they light up when driving at night times) . Before two days everything was working... it displayed everything perfectly (fuel used, mpg and everything...)
Does anybody know whats the problem... is it the fuse??
Thanks.
Old 01-10-2006, 02:14 PM
Can somebody help me out??
Old 01-10-2006, 04:34 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Driver's Info center displays nothing
Just to be sure check the DIC fuse but if your climate control is working OK it will probably be OK since the fuse is shared. How does the DIC look around the area of the car? Is it dim, faded or blank? There are about 5 back illumination lamps in the DIC.
Timeslip 08/12/06
AF Community Guidelines
Old 01-10-2006, 05:17 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: Driver's Info center displays nothing
Bad wiring harness?
Old 01-11-2006, 12:11 AM
its very faded and u can hardly see anything
Old 01-11-2006, 12:17 AM
BNaylor's Avatar
Re: Re: Re: Driver's Info center displays nothing
You can try replacing the bulbs in the DIC. It will require removal of the dash bezel and the DIC which is easy to remove. The lamps are special mini-lamps but Sylvania # 24 are suitable replacements. Available at stores like Autozone.
Timeslip 08/12/06
