Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 01-10-2006, 12:02 PM
TecChic's Avatar
TecChic TecChic is offline
No defrost
I have heat and it blows but only out the dash heater vents. When I switch it to defrost or floor it still blows out the dash. It will switch off also tho. Any ideas?
Old 01-10-2006, 05:44 PM
jsgold jsgold is offline
A lot of times it is a vacuum leak that causes this, as the controls are run by vacuum. Might check under dash for loose vacuum lines, maybe even on motor. Could be the actuator under the dash too, but usually the line is leaking somewhere.
I used to be indecisive, now I am not so sure.
