cone filter on 2.9l
I dont know much about engines so and i added a cone filter to my 90 ranger xlt, there is a wire attached to the air filter box, I was wonder what i should do with it, maybe drill a hole in the air intake piping and put it in?
Re: cone filter on 2.9l
You want no leaks in the intake tubing, I wouldn't recommend drilling a hole into it. The only place you should be getting fresh air from is through the cone filter. I am really not fimilar with the 2.3L from that year, is it the 2.9L? If it is, I am thinking there should be 2 lines that need plugged from the vacuum tap on the upper intake manifold. And the other should go to the MAP sensor. If it's any other engine, this won't apply. Basicially, you need to get fimilar with the vacuum mapping to know which systems you've eliminated. Once you determined what's not working anymore, you need to plug off the approperiate vacuum lines. I went with a MAF conversion and ended up eliminating an entire tap of vacuums on my 2.9L. Replaced it with a NPT brass plug and called it done. Much cleaner and easier to get the valve covers off if needed. DO NOT CUT the transmission vacuum line. Pete |
its the 2.9L Im not much for engines all i know is it was sucking air from the air intake box, what should i do with this line? havent really been driving it right now so i just taped it off so nothing gets in it while i work on the tranny
Re: Re: cone filter on 2.9l
Pete |
thanks alot, Iv noticed in alot of posts you give great info and help. this weekend im putting a new slave cylinder in and a 2 in body lift.
