Old 06-11-2002, 10:23 PM
Y2A Y2A is offline
Question 4G63 swap into Mirage
Is it possible to keep it streetable?
Old 07-04-2002, 02:00 PM
Taylor SPL Taylor SPL is offline
Send a message via AIM to Taylor SPL Send a message via Yahoo to Taylor SPL
Yes. Only problem is axles. My friend just sold his and it ran 10's.
1995 Talon TSi
[email protected]
Intake/BOV/IC Piping
Old 07-06-2002, 01:08 PM
Y2A Y2A is offline
So it's streetable? whats wrong with the axles? and your friend sold his 4g63 mirage that ran 10's, this was a streetable one?
Old 07-07-2002, 12:50 AM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
There are two different 4G63s, the eclipse one, and the newer lancer evo one. The evo one will be more expensive, but bolt right in. There are lots of problems with dropping the eclipse version in there though. For example, the tranny and stuff faces the exact opposite direction. Good luck
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
Old 09-28-2003, 02:30 AM
myrage myrage is offline
if you guys want ANY information about this sort of conversion, gimme an email at [email protected]
i have got the evo 5 engine in my coupe, so i know wat i'm talking about.
4G63 power!
Old 09-28-2003, 06:06 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
the colt have stronger axles
-Agim
Old 09-29-2003, 01:11 PM
BluFalcon's Avatar
BluFalcon BluFalcon is offline
Send a message via AIM to BluFalcon
Shouldn't this be in the Mirage Forum?
The swap is pretty straightfoward depending on the year Model of Mirage/Colt you want to swap the 4G63 into. If you're lucky enough to have one of the 89 Mirage/Colt Turbos with the 4G61T engine, then the 4G63 swap is a breeze, as the 4G63 will drop in with almost no modifications. Other model 89-93 Mirage/Colts can be converted to 4G63 engines but then you're going to have to swap in a DSM or Mirage Turbo wiring harness and find a set of motor mounts that'll work. Go to http://www.4g61t.com There are quite a few people on the board there that have done the 4G63 swap into a 89-93 car. if you have any questions about the procedure, they will be the ones able to answer them. Good luck.
90 Talon TSi/AWD "Project"
99 Galant GTZ "Driver"
http://www.dfwdsm.org
