Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 01-10-2006, 12:21 AM
gbic1 gbic1 is offline
90 Jetta blows oil out the dipstick tube
Is this a common problems on these cars. Afriend just bought this and it has good compression 155 160 155 160 If I release pressure by removing oil cap it stops spewing out the dipstick. Old escort 1.6s used to do this if the baffle in valve cover got blocked.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 06-30-2006, 12:07 PM
Doug Tatham Doug Tatham is offline
Re: 90 Jetta blows oil out the dipstick tube
Check the pcv valve. There aobut $80 so don't buy on if it isn't needed. They are a check valve mounted on the front right side of the valve cover. Air should blow through the tube that connects to the breather, but you shouldn't be able to blow air through in the other direction.
