5 Speed Manual Replacement
Hello I have a few questions for you guys. I have a 95 metro 3 cylinder with a 5 speed manual trans. It has recently exploded (250,000 miles) and I was wondering if any earlier models or later models or any trans from any other cars would be a suitable replacement. Such as from a Swift or a 90 or later Metro. Only reason I ask is there are none around here and I have found a Suzuki with a blown motor but good trans not sure on year though. Any help here appreciated. I would like to know it if would bolt right up, or if the clutch would have the same # of splines or if my current axles would fit. Thanks in advance!!!!
http://www.automotiveforums.com/vbul...t=transmission
My advice, stick with a 3cyl trans. Never drop a 4cyl trans in a 3cyl. The final drive is too large, and will take a toll on your acceleration and clutch. |
Re: 5 Speed Manual Replacement
transmissions ar the same and the clutch and axle splines will work with yours but you will barely be able to get going if you put the 4 cyl one in. your gear ratio should be 4.39 and the 4 cyl could be as high as 3.50. a normal 3 cyl metro from 89-94 is 4.10 so if you can't find one from 95-97 drop in a older one
Re: Re: 5 Speed Manual Replacement
Ok so get one from a 1.0 I got that. But are all of them the same for Sprint, Firefly, Metro,Swift? Is the housing the same? Will the axles from my metro work on all these, and will the clutch be the same? I really need to do this on the cheap I found a tranny from a swift for $100 and I want to make sure it will fit with little or no hassles. Thanks again! |
Re: Re: Re: 5 Speed Manual Replacement
Do it, it'll work. |
I wouldn't have said they were interchangable if they were different now would I have
. Like I said. EVERY sprint/metro/swift/firefly from 1989-2001 has the EXACT same splines, bellhousing, and external dimensions. Only difference in the gear ratios and final drive ratio. My GTi engine is running a 3cyl convertible transmission.
is the swift a 3 cyl? if its a 4 cyl; you will not be happy with it once you put it in, any metro from 89 up will work but 3 cyl is best interchange, same with a firefly. sprint will only fit if its a 89 or newer
Hello,
Are there any "better" 5th gear ratios that can easily be swapped to yield a better final ratio when cruising? A different trans that changes the ratio through all of the gears may not be ideal, but changing the top gear may have benefits to some. My previous car was a Jetta, and that was a common tweak for mileage. It was possible to swap the 5th gear out of a diesel trans into the gas trans to change the overdrive from 0.93 to 0.84. It was good for 3-5mpg. It did necessitate downshifting whenever attempting to accelerate while in 5th, but that's not a big problem. JW |
