Old 01-09-2006, 09:17 PM
h2point2 h2point2 is offline
Question bad hesitation/ slip
i have a 97 blazer 4.3 the tranny was just done about 9k miles ago. well from what i think it might be a torque converter but im not sure how they go out. the tranny doesnt really want to shift it has no power under load and it makes a 'supercharger' kind of noise all the time. the main reason i think it is the torque converter is when you gas it, its almost like a clutch is slipping it revs but doesnt go anywhere. from what ive said does anyone know or have ever had to deal with this problem.
if i give it alot of gas it jumps back and forth like when your first learning how to drive a stick...... but its a damn automatic
Old 01-10-2006, 06:50 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: bad hesitation/ slip
Is the check engine light on?
Have you tried manually shifting it to see if it will work any better?
Old 01-10-2006, 08:56 AM
check engine light apparently used to come on but now it doesnt and manually shifting it doesnt seem to help.
Old 01-11-2006, 11:16 AM
fam_mechanic's Avatar
fam_mechanic fam_mechanic is offline
Send a message via MSN to fam_mechanic Send a message via Yahoo to fam_mechanic
Re: Re: bad hesitation/ slip
I'd say take it back to the garage that rebulit your tranny.Sounds like the clutches inside the tranny might be slipping.?There is or was a torq converter solenoid plug somewhere on the side of ur tranny,might want to umplug it and run down the road to see if ur converter is "locking " in like its supposed to.
