Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-09-2006, 09:59 PM
fordfanatic69 fordfanatic69 is offline
Look at THIS
I wouldn't have bought it but I did for $0.01. Tell me what yall think if would work or not. CRAZY
http:www.kingenterprises.net/20hpmod.html
Old 01-10-2006, 09:30 AM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: Look at THIS
This does not work on modern vechiles.
We used to take out our IAT sensor - put it in the fridge for 20mins - then measure the resistance, then go buy the same resister and simply short it across the IAT sensor plug. The intent is to 'trick' the car into think it is cold outside all the time, therefore have it run rich, and potentially by adding the more fuel = more power.
Modern car will only be tricked of a short while and then either change the adaptive curve to call the new lower temperture 'normal' or throw a CEL light once it determines that something is not normal.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 01-10-2006, 10:57 AM
Re: Re: Look at THIS
Well I just love how people don't tell the truth anymore and will just sell you anything. Let me ask yall another question. Will a programer help this car out and be very noticable?
Old 01-10-2006, 05:36 PM
Quik_LS's Avatar
Re: Re: Re: Look at THIS
Yes.
I help guinea pig the first use of the SCT XCalibrator on the LS. I got mine from FastPartsNetwork.com - Torrie has now done many LSes and even had some on his dyno.
At MBT (mean best torque) I got 22rwhp - slight ping at WOT
I run daily with a 19rwhp tune, modified shift points, firmed SST shifting and remove rev limiter.
it is the best hp gain you can get from a mod.
see my mean LS
Old 01-10-2006, 10:24 PM
Re: Re: Re: Re: Look at THIS
Yes.
So you can modify shift points too. Do you have options on horsepower sttings like the diesels. And on the average how much does one cost?
Old 01-11-2006, 10:15 AM
Quik_LS's Avatar
Re: Re: Re: Re: Re: Look at THIS
The unit comes with three 'tune' files from the reseller (Torrie) and then stores your factory PCM code in it during first upload. So you can easily change between tunes - but it is a seperate upload (takes 5mins), veruses some of the diesel tuners where you can change it on the fly.
The XCalibrator2 has end user adjustments - injector size, speedo adjustment, timing, ....etc...
$399 http://www.fastpartsnetwork.com/sct1-X2.html
see my mean LS
