Old 01-09-2006, 04:41 PM
sdsniper's Avatar
sdsniper sdsniper is offline
Fuses?
Is there a fuse for the bright lights. My problem is that the bright lights wont shut off and im looking for the problem. The previous owner said he was down there where the fuses were and he thinks he messed up something down there. anyone know whats wrong?
Old 01-09-2006, 04:59 PM
CreepingDeath94 CreepingDeath94 is offline
When you say the brights won't shut off, you mean that when you turn your lights on they are always brights or that the brights are always on? If it is when you turn the lights on you only get brights, I would say it is somewhere in the switch on that column turn signal lever.
Old 01-09-2006, 05:32 PM
driftinggrifter2's Avatar
driftinggrifter2 driftinggrifter2 is offline
Send a message via AIM to driftinggrifter2 Send a message via MSN to driftinggrifter2
Re: Fuses?
Can you hear/feel the switch click on and off when you try?
F-Bodies Forever Member #2
guess bunny couldnt dominate the world!
Old 01-09-2006, 05:33 PM
Re: Fuses?
What does he mean when he was down there was he rewiring the fuse box or something?
Old 01-09-2006, 06:09 PM
sdsniper's Avatar
Re: Fuses?
I was underneath the steering column checking for a blown fuse or something. but when i trun on the lights, the lights are bright.
Old 01-09-2006, 06:20 PM
Re: Fuses?
Did the previous owner say what he was doing down there, if he wasn't rewiring it then i dont think there could of been much for him to mes up so im going to stick with CreepingDeath94 on this on.
Old 01-09-2006, 08:58 PM
sdsniper's Avatar
Re: Re: Fuses?
creeping was correct. I found out that the little stick on the column Is broken. Thank you creepingdeath94
Old 01-11-2006, 12:41 AM
sdsniper's Avatar
Re: Fuses?
I have one more question for you guys. For a 91 firebird where can the fuel pump be located. I was thinking inside the gas tank. I just want to make sure its in there before dropping the thing down you know. Its an all stock Firebird.
Old 01-11-2006, 04:36 PM
tri-power's Avatar
tri-power tri-power is offline
Yes. It's in the tank.
