Old 01-09-2006, 04:15 PM
essikr essikr is offline
engine misfire 2001 gt
I've read so much about MAF sensor problems as well as CAT convertors needing replaced on these models. I'm wondering if these symtoms point to the culprit.
2001 GP GT, 3800 series II engine ,87,000 miles.This is my daughters car and she tends to drive at the upper limit allowed. On several occasions the car quit and then ran ruff and misfired for a time.The service engine light blinked while this was happening and the engine temp went up higher than normal. Then the engine would smooth out like nothing was wrong. The service engine light stayed on for a time then went out. It comes back on any time the engine goes through the misfire again, which happens sporadically. The gas milage has gone from 22 to 17 MPG. If you rev the engine while in park the engine starts to miss at 4ooo rpm.
The codes that they pulled for me at the parts store were;P0300,P1361,P1362. Has anyone had the same symtoms or can point me in the right direction. Thanks for your help.
Puzzled Dad
Old 01-09-2006, 05:33 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: engine misfire 2001 gt
I believe you answered your own question but I'd put money on the CAT convertor. The symptoms you have are classic.
Timeslip 08/12/06
AF Community Guidelines
Old 01-09-2006, 05:53 PM
Thanks for the reply.I did forget to mention that new plugs and wires were installed a month ago.
Do you know what the codes mean?.You seem to know about Pontiac's.I was a certified Pontiac mechanic back in the 60's when thing weren't so complicated. Still love Pontiacs ,have a 91 Bonneville SSE still in excellent shape.
Also, does anyone know if a second owner of the car is covered for the replacement ? I sure hope so!
Old 01-09-2006, 06:54 PM
BNaylor's Avatar
Re: Re: engine misfire 2001 gt
Were the plugs and wires changed as a tune up or due to other problems?
P0300 = Random Misfire Detected
P1361 = Bypass Open Circuit Fault related to Ignition Control
P1362 - Bypass Short Circuit Fault related to Ignition Control
The misfire is consistent with possibly the CAT being bad. Misfires will cause the CAT to heat up above specs. If it were one specific plug or wire a more specific code such as P0301 would be generated indicating cylinder #1 misfire and so on.
P1361 and 1362 could be consistent with the CAT but are probably triggering due to variations in the crank position angle which can be caused by misfire. The PCM uses the 18X pulses generated off the Crank Position Sensor in an attempt to put the system into bypass mode. From the 18X pulses, 3X pulses are processed by the ignition control module and then to the PCM module. These codes can be generated due to a defective ICM module or PCM too.
Once the source of the random misfires is resolved the other two codes will probably be resolved.
I'd recommend that you check with the local GM dealer but they should honor the extended emissions warranty on the CAT which is now 10 years or 120K miles, whichever comes first on a 2001 - 2002 Grand Prix regardless if you are not the orginal owner. Good luck!
BTW - I forgot to mention that the dealer can test for excessive exhaust backpressure/CAT by running a low pressure test fixture at the front 02 sensor. The reading cannot be over 1.25 psi.
Timeslip 08/12/06
Old 01-10-2006, 12:50 AM
Thanks again,you must have read my mind about why the convertor can cause an ignition problem.The tune up was not done because of the problem ,it came later. Do you know what the thread type and size is on the O2 sensor?
Old 01-10-2006, 07:37 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I know the thread diameter is 18mm, and I believe it's a 1.5 thread pitch, it's course thread metric, which I believe is 1.5. The stupid Delco catalogs don't give specifications anymore.
Old 01-10-2006, 09:38 AM
BNaylor's Avatar
The typical GM Oxygen Sensor Bung size for sure is 18mm x 1.5 thread.
18mm X 1.5
If you plan on running the test yourself you will need a low pressure 0 - 5 psi gauge. Backpressure reading should not exceed 1.25 psi.
Timeslip 08/12/06
Old 01-10-2006, 04:31 PM
Great info! Went to the dealer to see if it was under warranty .He didn't know anything about the extended 10 year 120,000 warrenty.Does anyone have an actual copy of the letter that was sent out?Anyone have one over 80,000 miles that was covered and maybe a second owner?
Old 01-10-2006, 04:44 PM
BNaylor's Avatar
Here you go.
This is a special policy that raises warranty coverages on the converter in case you experience a failure.
Dear General Motors Customer:
As the owner of a 2001-02 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix; or Buick Regal model vehicle, equipped with a 3.4L or 3.8L V6 engine, your satisfaction with our product is very important to us.
This letter is intended to make you aware that some 2001-02 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix; and Buick Regal model vehicles, equipped with a 3.4L or 3.8L V6 engine, may have a condition where the catalytic converter is replaced due to complaints of lack of power or illumination of the Malfunction Indicator Lamp (MIL). This may be due to the front endcone insulation from the catalytic converter breaking away and blocking the front of the first catalyst brick and preventing the free flow of exhaust gas through the converter.
This is not a recall. Do not take your vehicle to your GM dealer as a result of this letter unless you believe that your vehicle has the condition as described above.
What We Have Done
General Motors is providing owners with additional protection for the Catalytic Converter. If this condition occurs on your 2001-02 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix; or Buick Regal model vehicle, equipped with a 3.4L or 3.8L V6 engine, within 10 years of the date your vehicle was originally placed in service or 120,000 miles (190,000 km), whichever occurs first, the condition will be repaired for you at no charge .
What You Should Do
Repairs and adjustments qualifying under this special coverage must be performed by a General Motors dealer. You may want to call the service department at your dealer to find out how long they will need to have your vehicle so that you may schedule the appointment at a time that is convenient for you. This will also allow your dealer to order parts if they are not already in stock. Keep this letter with your other important glove box literature for future reference.
Timeslip 08/12/06
Old 01-14-2006, 02:25 PM
Back again,thought the problem was fixed.Had the cat convertor(no help from the dealer) replaced with a Magnaflow. The one removed was plugged the honeycomb was all in pieces. The car has more power but the misfire is still there. After it was replaced I drove about two miles ,the car was running great .Then all of a sudden started the misfire.I could here it poping through the intake. The car could only go about 30 MPH.The engine light came on flashing,went about a 1/4 mile and it was like a switched was turned on .It ran fine again and the engine light went out. Have any ideas's ????
Old 01-14-2006, 02:40 PM
BNaylor's Avatar
What I do know for a fact is the 3800 is sensitive to the spark plug wires and spark plugs. What brand did you use? Whenever the SES light flashes it indicates a misfire conditon.
Also disconnect the electrical connector to the MAF sensor and test drive it. The PCM will detect no MAF input and revert to pre-programmed air flow values. It won't hurt anything. The idle may be a little erratic until the engine warms up.
Timeslip 08/12/06
Old 01-14-2006, 03:01 PM
Thanks for the quick reply, I checked the plugs they are Delco 41-940 .The wires are new but they are not Delco.
I reved the engine in park and at 4000 rpm it misses,I tried disconnecting the maf sensor ( at least I think it was it? ) and reved the engine and it still missed at around 4000 rpm.Which one is the maf sensor?
Old 01-14-2006, 03:12 PM
BNaylor's Avatar
The best plugs to use are the AC Delco 41-101 Iridium. If the 41-940 are double platinum they could cause problems. The other AC Delco plug that works is the Rapidfire #14 Platinums. The wires recommended are the AC Delco Premium Silicone 7mm.
The MAF sensor is the square black module located on the top of the throttle body. The PCM has a rev-limiter that kicks in at around 4000 rpms so it will be normal for the cutoff in park or neutral. Try testing on the road with MAF disconnected. If that doesn't work then wires and plugs are the most likely cause.
Timeslip 08/12/06
Old 01-14-2006, 03:28 PM
the.dude's Avatar
the.dude the.dude is offline
My MAF sensor gave me a heck of a time this past week, My car had eveyr engine code in it BUT the MAF. So, don't rule it out. Good Luck.
Old 01-14-2006, 03:57 PM
BNaylor's Avatar
BTW - One other thing......the plugs you are using AC Delco 41-940 are incorrect for the 3800. They are the standard plugs in a GM 3.4L 3400. How did you come about using those plugs? They did not ring a bell so I checked them out for you and found the above.
The AC Delco Rapidfire 14 Platinum or 41-101 Iridiums are the specified spark plugs for your model GP.
Timeslip 08/12/06
