Old 01-09-2006, 03:29 PM
baldhead baldhead is offline
96 when stopped in drive idles from 500-800 and drops back down
i replaced the fuel filter and have an air filter on the way this happens wether the a/c or heater is on or off. slowly builds up then drops back down. thanks for any input.
Old 01-09-2006, 05:01 PM
bpolley bpolley is offline
Re: 96 when stopped in drive idles from 500-800 and drops back down
It sounds like you have an EGR valve going bad. But there is always the possibility of having a vacuum leak. I would start there. It doesn't cost anything. There are many other culprits to this problem though. Some can be a little costly. Good Luck.
Old 01-09-2006, 10:38 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
And just for good measure, if you haven't already, add a bottle of fuel injector cleaner to the fuel tank and run that 50 miles or so to see if that helps out.
-Rod
Old 01-10-2006, 08:36 PM
thanks I run lucas fuel treatment every couple of months but i did find a pinched vacuum line that runs from that plasic intake hose towards the firewall will see if that helps the problem
Old 01-10-2006, 10:11 PM
shorod's Avatar
SHO No Mo
Fixing that pinched vacuum hose probably will fix your problem. Good catch.
-Rod
