Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-09-2006, 12:26 PM
dukhunter925 dukhunter925 is offline
Help 1985 toyota 4x4 pickup electrical prob!
i have a 1985 yota 22r carb'd. i drove to work and stoped it then after work i tried to start and the only light that came on was the charge light. usually all the dummy lights come on pre starting the truck. tried to jump it... didnt work. when i turn the key nothing happens not even a clicking. i then push started it and the truck ran but still none of the lights worked (taillights, brake lights, fuel gauge, heater, stereo, dash lights) only thing that worked was the headlights. when i stoped it at my house it did that same thing. i was told it was possibly a relay or a master fuse. i replace the m3 relay and that did no help. any help would be great. thanks Zack.
update, i just replaced the "head" relay and that didnt do it.
could it be the "cmh, heater, fuel" relay?
Old 01-09-2006, 02:55 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
There are a number of fuses and fuseable links in the fuse box under the hood you can check.
Is your charging system working properly ?
You may want to have the alternator and battery tested.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-09-2006, 05:27 PM
imc188222 imc188222 is offline
Re: Help 1985 toyota 4x4 pickup electrical prob!
The first thing to do when something of that nature happens is disconnect the battery clean the terminals and make sure that everything is tight. If you have the aftermarket terminals that clamp the cable you need to take that apart and clean it too. Those are legendary for coroding.
Old 01-11-2006, 06:27 PM
yeah the clamps are aftermarket, and i cleaned them and make sure all the wires are tight. my alternator is almost new, is there any fusable links between the fuse box on the wheel well and the fuse box in the cab? i dont know what the dang problem is. thanks for the comments. hopefully i can get this think runnin
Zack
Old 01-11-2006, 07:10 PM
just checked fuse box, i am getting 14.XX voltage @ the ign. fuse but everything else i dont get anything. i am confused.
Old 01-14-2006, 01:26 AM
KimMG KimMG is offline
AF - Advisor
Is power coming out of fuse? Get a wiring diagram for your vehicle. It will show what the fusible links are connected to and what color wires to look for. Use it to mark off what you have tested.
I had a similar problem on a Celica. It turned out to be a burned plug on the back of the fuse panel under the hood.
Old 01-15-2006, 05:51 PM
found problem.... wiring to alternator was boken. however now its running like shit. dont know why
