Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
View Poll Results: Should I sell this old camry and buy a cheap new car like Hyundai?
Yes 1 10.00%
No 8 80.00%
Hyundai-never touch 1 10.00%
Voters: 10. You may not vote on this poll
Old 01-09-2006, 11:34 AM
atmreza atmreza is offline
Question '95 Camry Transmission
I have a '95 Toyota Camry LE, 162k mileage. It runs really good. But recently I noticed it vibrates a lot while going from 55mph to 60mph. It vibrates at this range only if I press gas pedal.
I took it to Mr. Transmission, after test drive, they can't say anything about it. They suggested I pay them 200 dollar to open the transmission to check. I check with Toyota and they'd charge 400 for the same job.
Any suggestion? Is it a big problem with the transmission?
I recently replaced sparkplugs to reduce some vibration. This car also needs the engine mount to be replaced, the repair bill is going up....
Old 01-09-2006, 12:42 PM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Re: '95 Camry Transmission
Not sure which mounts they were referring to, but copied this some time back, sounds like your sympton:
Alex Marcuzzi wrote:
> I have a 1993 Camry and it vibrates starting at 50M.P.H. and then it
> gradually disappears when it reaches 60-65 M.P.H.. I have balanced the
> wheels, moved the tires from front to rear and did a wheel alignment.
> Anyone else have any ideas. Other then those speeds it runs pretty
> smooth.
> Alex
I have had the same problem for years and finally found the source---worn
motor mounts.
Old 01-09-2006, 01:07 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Replace your dogbone mount.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 04-04-2007, 01:16 PM
gator2764 gator2764 is offline
Don't forget your CV axles. This could be the cause as well. Even if they are not clicking when you turn hard I have seen this exact problem, just yesterday on a 93 Corolla.
Old 04-04-2007, 02:34 PM
somick's Avatar
somick somick is offline
...and don't forget to look at the date. This post is over a year old!!!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 04-05-2007, 05:23 AM
Sam
DOH!!! Guess I better look a little closer next time.
