Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-09-2006, 09:24 AM
copcarcrzy copcarcrzy is offline
Door Seals
How hard is it to replace the door rubber on a 1990 4 dr Caprice, Mine leak real bad.
Old 01-09-2006, 09:36 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Door Seals
It just pushes into the channels along the doors - a little rubber cement might also be used to help retain it, however it should come out fairly easily. The only problem is the stuff is EXPENSIVE - a couple hundred dollars per side - but it is still available through GM.
Old 01-10-2006, 04:59 PM
TommySS TommySS is offline
Re: Door Seals
You can order through JC Whitney and get 'em for much less - and I think their vendor is SoffSeal. Make sure the channels are clean too.
The "original" sponge-type seals are the best, but I think GM is the only place that sells them. The SoffSeal units will get the job done though.
The station wagon tailgate seal is a LOT, but still obtainable (for now)
