Old 06-11-2002, 06:10 PM
Steel's Avatar
Steel Steel is offline
front alignment question
ok, you can see what my car is <-- and the problem is:
the steering pulls to the right, moderatly hard. Now the inside of the tread (part closest to the middle of the car) of the front left tire is wearing out faster than the outside, and the inside of the front right is doing it too, but not nearly as bad.
Is this a toe, camber, or alignement problem, or a combination of the three? Aobut how hard is it to fix, and finally, could i switch the two front tires after ni've fixed the problem so that they wear correctly?
Thanx for the help.
Old 06-11-2002, 08:52 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
note: toe and camber problems are both types of alignment problems
Is the wear in a scalloped pattern, or is it pretty even all the way around?
It sounds to me like it might be a toe problem (toe out)?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 06-12-2002, 12:16 AM
Steel's Avatar
its pretty even, but only on one side of the tire
Old 06-12-2002, 08:27 AM
enginerd's Avatar
enginerd enginerd is offline
Your camber is out of adjustment. The top of the tire is closer to the vehicle when compared to the bottom of the tire. Thus pushing the car to the right like leaning on a motorcycle.
Old 06-12-2002, 08:55 AM
yeah, given that the wear is even, that sounds reasonable... now the question is whether or not camber is adjustable on that vehicle...
