Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-09-2006, 04:33 AM
romanone romanone is offline
2002 sunfire help needed
i have a 02 sunfire with 2.2 L engiene not an ecotec. The fuel level started to show wrong the fuel tank is half empty but it says that it's almost full. A few days ago i tried to start a car but it won't start with a half tank of gasoline. i had to put almost 8 gallons to make it start. this problem repets all the time. What could it be? the biggest problem is that i am in europe and need to order parts online if needed. So iof you guys know what could it be please specify the part in the term that i could find on internet/ thank you
Old 01-09-2006, 09:44 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2002 sunfire help needed
What you need for your car is a fuel tank level sensor and sending unit. You can try all the good sites like rockauto.com or gmpartsdirect.com to find one. I looked it up but didn't know which vin your engine corresponded to so once you search you should be able to find it. You will have to remove the fuel pump to change it though which can be quite involved. Good Luck!
Old 01-09-2006, 02:42 PM
Thank YOU very much! Only few questions remain. I have got this car as a gift and as you know i am in europe. i don't know how to find out which vin my engine corresponded to . My vin number is 1G2JB124127124961
Old 01-10-2006, 04:57 AM
Fuel
what i found on gmpartsdirect.com is
GM PART # 25691383
CATEGORY: Fuel Tank Meter Sender/Connector
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $8.61
OUR PRICE: $4.31
DESCRIPTION: CAM F/SDR
and
GM PART # 88966972
GM LIST: $129.40
OUR PRICE: $64.70
DESCRIPTION: SEN KIT
and
GM PART # 25712454
CATEGORY: Fuel Gauge to Tank Seal
GM LIST: $14.52
OUR PRICE: $7.26
DESCRIPTION: SEAL
i ca not use the rockauto.com because they don't send stuff to my counrty. are those part i found right or not?
Old 01-10-2006, 05:01 AM
fuel
as I just found out gmpartsdirect.com doesn't ship internationally either i will buy from rockauto and send it to my friend's address in florida.
it has to be FUEL TANK VALVE SENSOR,
FUEL TANK SENDING UNIT and SEAL
am I correct?
Old 01-10-2006, 10:56 AM
Pontiac Guy
Yes! Good Luck! Before you order I would call them to make sure that is everything you need to replace the unit. Sometimes they have different numbers for small items. By the way your engine vin number is 4 the others are F or T.
Old 01-10-2006, 01:13 PM
thank you very much
