Old 01-09-2006, 03:19 AM
nyexchange nyexchange is offline
steering fluid leak
my 95 buick lesabre is leaking steering fluid for about 6 month now. it usually takes about 32 ounce a month to keep it from being empty and making grinding noise.
could someone tell me what i need to replace to fix this problem?
i don't want to get overcharge when i go to fix this problem. one guy at my oil chane place said that i only need to change the steering fluid which include the pressure vales and stuff and that should be able to fix the leak for $150. another guy at at a different place said i need to replace a few things and not just 1 component, which will cost $500, which i think he is trying to scam me.
Old 01-09-2006, 03:31 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: steering fluid leak
Can you see where the source of the leak is located? You could be lucky and simply have a leak at one of the hoses. If that's not the case, I'd go with the $150 quote, 500 bucks is ridiculously high for PS maintenance
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-10-2006, 04:32 PM
yogi_123rd yogi_123rd is offline
Interesting -- I too had a pin hole leak. Turns out the system has an oil cooler. A steel line goes to the driver's side front of the radiator and back again as a well as a line going to the rack and pinion. It corroded into a small leak. Look for the leak near the radiator where the line is exposed.
To repair the line, just cut out the steel tubing that's bad and add a rubber hose with clamps.
PS. total code of repair: 2 hose clamps, 1 rubber hose, and 15 minutes of work.
