Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-09-2006, 01:17 AM
tardster tardster is offline
Squeeking noise
Hey guys, I need some help please. My car is making a squeeking noise pretty bad, it kinda came out of nowhere. I have narrowed it down to the frant passenger tire or strut or something in that area. When I turn a corner, or hit a bump it squeeks. I even pushed down on the front of the car and it made the noise. Is there something that could be going out on it like the ball joint, strut, spring, some sort of bushing somewhere. Any help is greatlly appreciated. Thanks...
Old 01-09-2006, 02:17 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
hmmm usually when you push up and down on a corner and it squeeks I'd say ball joint. However I'd recomend jacking up the offending tire and seeing if the tire wobbles at all and maybe peek underneath and see how the ball joint looks.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 01-09-2006, 03:12 PM
WReX WReX is offline
Re: Squeeking noise
that squeeking could be lower ball joints or possible a wheel bearing, is there any kind of "wom wom" sound from the car over 30mph or so? (don't get that wom wom confused with the tires)
26 PSI anyone?
Old 01-09-2006, 03:56 PM
The noise is mainly when I turn a corner and if I hit a bump.
Old 01-09-2006, 06:02 PM
Re: Squeeking noise
its most likely ball joints on the lower control arm
26 PSI anyone?
Old 01-10-2006, 05:46 PM
96 civicturbo 96 civicturbo is offline
Send a message via MSN to 96 civicturbo
check the tie rod end to. try to move it back and fourth. if it is hard to move then it is most likely bad.
Old 01-11-2006, 04:37 PM
Ok I just got done jacking the car up, I tried moving the tire back n forth and up and down and there was no movement at all. Im wondering if maybe its the strut itself maybe going bad or if the bushings which do look abit worn could be causing it. The tie rod ends have been replaced within the last couple years, do you think maybe the stuff could be abit to tight?
Old 01-12-2006, 12:32 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
Re: Squeeking noise
Get some white lithium grease in a spray can and spray it liberally on your ball joint. I had a pretty decent squeek when i turned and that rid of it like it was a brand new ball joint. If it is really your ball joint, this will temporarily fix it but eventually it will have to be replaced, just not anytime soon.
