Old 01-08-2006, 09:19 PM
welfarepc welfarepc is offline
Question cv joint click, what side?
my axles were clicking, so i went to the junk yard and got 2 replacements...
so i got 2 used axles from a junk yard, and i still get a click when turning, but only when turning all the way left, when going forward.
can u tell which side is gone by which way ur wheels are turned when it clicks? or does anyone know a good way to check what side is fucked? thanks boys
Dan
Old 01-08-2006, 10:14 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: cv joint click, what side?
your best bet is to just go get some new ones and replace both of them...if you don't have the money for both, get 1, then get the other when you get the chance. I work at a salvage yard and I wouldn't trust the axles that come out of those cars, especially older cars like ours.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-08-2006, 10:35 PM
good call, the only reason why i got them was because it was only $100 canadian for both, and they got a 3 month warranty... so its free. any suggestions on how to isolate the side? thanks
Old 01-08-2006, 11:51 PM
Tony's Avatar
TLD Member #1
no ideas on figuring out which side its coming from, i just always replace both at the same time. I know the axles are only like $50-55 a piece in the states for new ones, its the core price that gets you.
Tony
Old 01-09-2006, 12:04 AM
GTA's Avatar
GTA GTA is offline
Whee..
i just go to autozone. buy a pair and the lifetime warranty. anytime they make noise replace em for free.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 01-09-2006, 07:08 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
go to an open space, take a buddy. Pop the hood, have the buddy walk close by as you turn slowly.Try not to run your friend over though...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-09-2006, 07:10 PM
curt_h curt_h is offline
If You are making a left hand turn when you hear the noise it is the r/h half shaft that needs replaced. At least it has been on all the ones I have changed.
Old 01-09-2006, 11:25 PM
BullShifter's Avatar
I've driven cars with one bad axle that noise regardless of direction. If you can't visually see it, take jeef's advice. I don't see the reason for the open hood.
Old 01-10-2006, 01:07 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Not trying to be a dick, but thats really not true at all
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-10-2006, 01:36 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Find a parking lot and start driving backwards. This should exaggerate the symptoms because it'll shift the stress points inside the joints. Do a tight slalom in reverse and note when the problem is at its worst -- because of the way torque is applied, the wheel on the inside of the curve will complain the most.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-10-2006, 02:43 AM
justin476 justin476 is offline
Re: Re: cv joint click, what side?
just had a quick question to add. I think mine are going too, it makes the click bla bla. but should it make one single click? or a few? cause on my old 4dr it made ceveral small clicks, but my new si makes one big one. It also makes it when i brake sometimes, thats why i didn't know if it was my cv's or not. thanks
Old 01-11-2006, 02:06 AM
thanks for the suggestions, ill go to a parking lot and try the reverse thing, and ill bring a buddy to listen for the side... thanks for the ideas.
