Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-08-2006, 08:57 PM
beegolden beegolden is offline
98 Eclipse Poor running and Backfire
I just purchased a 98 Eclipse with 94K,this car has very bad exceleration and backfires once in a while. Now to explain when you start off at an idle it take some time to excel it is like something kick in and give it a short burst of energy and then back to poor exceleration this does this regardles of hot or cold. This is a ebay car that I drove 650 miles to my home. In searching I found alot about the IAC and the TPS, does anyone think this could be my problem or please point me in the right direction.
Thank you
Old 01-08-2006, 09:00 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: 98 Eclipse Poor running and Backfire
turbo or non?
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 01-08-2006, 09:02 PM
Non Turbo
Old 01-08-2006, 09:07 PM
SLoe's Avatar
SLoe SLoe is offline
Backfire makes me think ignition system problems. Put your car info in your signature to save time in the future, WHEN you have your next problem.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-08-2006, 09:21 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Check your plugs and make sure they are ok, I would probably replace them regardless to be safe. Check your plug wires. Check the coil. Try those 3 things first, like loeman said a backfire is usually an ignition issue
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-09-2006, 12:56 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
is your engine light on?
Old 01-09-2006, 06:02 AM
Re: Re: 98 Eclipse Poor running and Backfire
Thank you,
I wll replace plugs and wires and go from there
Old 01-09-2006, 09:01 PM
Re: Re: Re: 98 Eclipse Poor running and Backfire
Replaced plugs and wires and the car runs 100% better, still smells a little rich but I can't complain.
Thank you
Old 01-09-2006, 09:17 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: Re: Re: 98 Eclipse Poor running and Backfire
Thank you
Did you re-gap them? What plugs did you replace them with...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-10-2006, 04:53 AM
SLoe's Avatar
Thank you
Great, I'm glad it worked out.
Old 01-10-2006, 06:17 AM
Re: Re: Re: Re: Re: 98 Eclipse Poor running and Backfire
I used Bosch double plattin plugs that stated they did not regaped also used Duralast wires.
David
Old 01-10-2006, 12:17 PM
Re: Re: Re: Re: Re: Re: 98 Eclipse Poor running and Backfire
David
Theres your problem for running rich. Wrong plugs my friend. Unless you feel like dropping another $12 on the correct plugs, don't worry about it.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 01-10-2006, 05:42 PM
WrecklessMM's Avatar
WrecklessMM WrecklessMM is offline
my 1997 gst had idling problems. everything lead me to the iac and throttle body sensors it ended up being the ecu engine computer under the dasboard. picked one up a junk yard for 175 never kno could be your problem
Old 04-15-2007, 08:09 PM
400sbc_guy 400sbc_guy is offline
Angry Re: 98 Eclipse Poor running and Backfire
i just bought a 96 eclipse rs 2.0 dohc non turbo auto. needed a crank sensor and a ecm. got it started and runs good @ idle. rev up and it cuts back and fires out exh. cut cat off put new plugs ngks and no improvement anyone know how to fix or have same problem?
91 s10 400 (484/494 cam)1.6 roller rocker,typhoon intake,800 cfm thunder avs carb,250 shot nos,5 speed,tubbed rearend w/ drags....chromed down 2 10in memphis hpo in a reg cab
Old 04-15-2007, 08:22 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Please check the last posted date of a thread before bringing it back from the dead... Do not bring back threads older than a month unless you are the original poster of the thread or have some critical information that needs to be added to a thread...
(AKA, you should probably make a new thread for your problem in the problem diagnositics section... Thank you.)
Locked...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Closed Thread
