Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-08-2006, 09:33 PM
seanish4042 seanish4042 is offline
Knock Sensor or O2 Sensor
Whatsup...
Recently my milage has been awful, as low as 14.1. I also notice a slight loss in performance. The seemingly happened after I had my WSP y-pipe installed. I might be wrong though.
I ran an ECU check after i got it installed and it now throws a knock sensor code. I saw in an earlire thread that THT said sometimes the knock sensor code actually means an O2 sensor is messed up. I dont have an 02 sensor code though.
I dont want to go buy a knock sensor then not have the problem be solved. I dont know if i hear a pinging noise, is there a way to check?
thanks.
Old 01-09-2006, 03:00 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Knock Sensor or O2 Sensor
Originally Posted by seanish4042
...is there a way to check? thanks.
O2 sensors produce nice on/off signal fluctuating between 0 to 1V, frequency depends on rpm. Measurable with dmm from ECU pins and/or O2 connector wires, connectors. ECU has also selftst for O2.
For KS you need a tester (for some reason ?? ECU cannot always detect), buy or lease or goto a shop for this specific tst. Dead KS means real bad mpg. Bypass resistor is one way to tst, gives performance boost IF KS is dead. See http://www.cardomain.com/ride/748507/9
Old 01-09-2006, 11:24 AM
Re: Re: Knock Sensor or O2 Sensor
Thanks a lot, you are very knowledgeable.
Unfortunately, as a 21 year old, I really dont oknw much about electricity and bypassing and resistors, etc.
I was able to locate the knock sensor on my 95, but its very hard to get to.
Assuming the KS is dead...how do i bypass it?
It does not really give step by step instructions on your site.
Old 01-09-2006, 01:12 PM
Re: Re: Re: Knock Sensor or O2 Sensor
....how do i bypass it?...
Get any resistor, 0.5Mohm is ok. Unplug KS connector. Push the resistor into connector, ECU-side. Hit tst the autobahn...
see at http://www.cardomain.com/ride/748507/9
Old 01-12-2006, 06:22 PM
Re: Re: Re: Re: Knock Sensor or O2 Sensor
got it...i think im just gonna get a new KS though. any estimates as to time required to install if the intake manifold has to be removed?
Old 01-13-2006, 02:13 AM
Re: Re: Re: Re: Re: Knock Sensor or O2 Sensor
Dunno as I havent done that job
Over 100 yrs engines have survived w/o KS. Maybe its the modern drivers who cannot comprehend and will not adj/clean engines if knocking occurs. ...or stereos?
Stealership will give you a quotation, time & spares. Thats 2x price u should pay, third of the time for first DIY.
Old 01-15-2006, 08:40 PM
Mrbizness1 Mrbizness1 is offline
It will cost several hours labor plus about $150.00 for a sensor. About $450 to $500. I found a shop that specializes in Nissans, they made a special tool and replace them in 20 minutes. I bought a sensor on ebay for $100 including shipping
Old 01-18-2006, 04:11 PM
yeah i can get one for 70 on ebay shiiped.
my boys dad owns a garage, hopefully i can him to do it pro bono.
Old 01-29-2006, 05:16 PM
i think im gonna try the bypass.
keep in mind i have a 95, walt, and i konw you have the earlier generation so the set up in terms of the knock sensor is differnet.
when you say disconnect the sensor...do you mean...
unplug the sub harness from the KS itself, then shove a resistor in where the sub harness normally connects to the KS?...
is that right? or is there another part of the connector towrads the front of the engine that is a lot easier to access that i am going to be putting the resistor in?
Old 01-30-2006, 03:04 AM
...where the sub harness normally connects to the KS?...
I guess theres only one KS connector, engine bay. As its disconnected, KS is dead weight, computer side now floats and needs input. This is a pull down resistor, which affects (pulls down & stabilizes) ECU input.
After bypass, do not lend the car "for Colorado holiday trip for friends". Theyll accidentally fill 87octane, then, (not hearing noises) will push pedal uphill. Engine: 4 minutes lifetime left...
Lots of cars I've driven have produced ping. When its heard, loosening pedal will stop this (=less load). My Opel had the mech adv broken; terrible noise uphill. Engine doesnt die immediately if ping happens, one has to drive accordinly, less load, higher rpm. Our forefathers drove 100years without KS... Ignorant ppl will definitely blow engine; that is why Nissan & others want to include a safety device.
Old 01-30-2006, 10:34 AM
http://www.courtesyparts.com/Merchan...Code=22060-A32
there is a picture of the harness. as you can see it connects in two places...one to the KS itself, and one somewhere else. where should i be putting the resistor?
by the way...is the pic in ur avatar from 'The Black Hole'?
Old 01-30-2006, 11:09 AM
....avatar from 'The Black Hole'?
- When u put the KS in your pocket, all wires connected, you have only one free connector, one choice: plugin the resistor.
-Even if you put that short KS-wire in your pocket (shown in the pic), you still have left one open KS-connector under the hood - one choice: if this connecter wiring is followed, ECU will be found in the opposite end. Its like the pic on this thread, above.
put .5MΩ here↓-or- here↓
ECU________┌ _______┌ _K
ECUŻŻŻŻŻŻŻŻ└ ŻŻŻŻŻŻŻ└ ŻS
Avatar: Whoa! It took one year for anybody to ask. In a way it is as u say: My carriage horses=VGE has two throats. The picture is from one throat, plus some phot-o-chop. In a way its the 'eternal sucker', source of my pwr....
Old 01-30-2006, 05:24 PM
i wish i had pictures to show you. theres so mayn damn connectors.
Old 01-30-2006, 06:38 PM
holy shitttttt. i just figured it out...checked the code...its gone! took it for a test drive...hollyyy shitttt..
below 3000 the thing is an animal again. im so happy.
i am getting an 0505 now, which i hear is common...what is it?
Old 02-05-2006, 11:37 AM
...below 3000 the thing is an animal again. im so happy.
...sorry, I must have missed your q:
0505 No self diagnostic codes present (http://www.cardomain.com/ride/748507/21)
I had same feelin after bypass 'surgery' 2yrs ago. Now either keep the beast on hi octane diet or plan for new KS. Periodic [seafoam or smtg] cleanup will not hurt; peek on plugs will tell if thats necessary. Compare to NGK.com troublechart pics.
