Old 01-08-2006, 07:14 PM
garceau83 garceau83 is offline
1990 Voyager 3.3 missing and backfiring
Help. I have a 1990 Plymouth voyager with the 3.3 engine that ran perfect until last week. It has 90K miles. Was driving at about 15 MPH and stepped on the gas a little and got a big backfire. It did it once again when I stepped on the gas.
I made it home with out any problem. I then noticed it would backfire everytime I took off. It was getting worst by the minute.
I replaced the plugs and wires and it didn't help. Backfiring and missing got worst. Would idle a little rough but had deep explosions when taking off under load. (In gear with foot on brake) It sounded like a machine gun.
Replaced the fuel filter. still the same thing. Pulled both valve covers and checked for broken rocker arm towers or broken springs. they were ok.
Did compression test. They were 140 -150 PSI. The number one plug was black as if it had been used for years. The other five were like new. Nice and shinny. I believe the #1 cylinder is the one that is doing the missing and backfiring. I have asked just about everyone and they don't have a clue. Could the engine controller cause this. the only code i get is 55.
I can do the wokrk, just tell me what to do.
Thanks to everyone who reads this post and considers a fix.
Old 01-15-2006, 11:45 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 1990 Voyager 3.3 missing and backfiring
Did you replace the coil pack or see if you can have it checked at one of the local auto parts stores? Check the electrical connector to the coil pack also.
