Old 01-08-2006, 06:40 PM
|WYG|SS |WYG|SS is offline
Low idle problems
I have recently posted about the oil light comming on and check engine light. i have a 2.2L 91 sunbird. My dad and i have replaced the PVC thing that is connected to the crank case like a week ago and it ran fine then later today when driving the oil light started to come on again, it was going into low idle. so me and dad looked at the carberator and looked at the breather filter and it was really dirty and whe had went and got a new one and it was still going into low idle. (IS THE BRETHER TUBE SUPPOSE TO BE BLOWING AIR OUT OF IT(SHOULDT IT BE SUCKING AIR IN?)?) Anyone know what might be wrong?
Old 01-11-2006, 01:28 AM
swingline swingline is offline
Re: Low idle problems
sounds like you have some high crankcase pressures that is most likely caused by combustion chamber gasses blowing by compression rings. I'm guessing your car has a few miles, it being a 91 and all. do a compression test, it may only be one cylinder or something. i'd say it's time to overhaul or look for a new ride.
Old 01-11-2006, 03:26 PM
well when i got it it had 129K on it but ill look into that because the body is still good and and i dont want to junk it so ill get that checked.
Old 01-11-2006, 03:58 PM
cause when we replaces the PCV thing going into crank case that is a vaccume my dad tooking it off and it went into high idle but then that day we have taken it off and iddle stayed the same
