Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 01-08-2006, 05:10 PM
Livewiresinc Livewiresinc is offline
Angry 1995 LHS Tranny Problem
I just purchased a 1995 LHS and for some reason the transmission will not down shift. It stays in 2nd gear(limp mode). There is no leaking transmission fluid, No Smell of burnt transmission fluid. Was wondering if this could be an electrical issue with the TCM, or something else as the trac light in the message area is light but cannot engage or disengage the button. I have no control over the heater as it blows out heat with out being on, dont even get a display. Starting to doubt this wonderful looking trojan horse
Old 01-08-2006, 05:56 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 LHS Tranny Problem
First thing is to go for a code check on the eng/bod/trans computer systems with a body/trans/engine capable scanner.
A free OBD11 code check may help but does get deep enough for the good codes.
If any codes post back codes.
MT
MT
Old 01-08-2006, 09:56 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
if you can, find out what type of fluid was last put in the transmission. Chrysler transmissions are notorious for acting up if the wrong fluid is used. Only Mopar ATF+4 is the only thing that should be used inside of your transmission; anything else will cause problems for your car.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 01-09-2006, 08:53 AM
Thanks fellas, gonna try both
