Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-08-2006, 05:07 PM
Swampy53 Swampy53 is offline
1997 Sunfire start problems
I have a 1997 Sunfire 2.2 Liter, automatic transmission. Had for about a year no problems until the other day. Cut the car off, was fine. Went to start it in the evening it would not start. Turned over but did not start. Check engine light was off. Checked sensors, wiring, relays, and grounds and located no problems. Removed the negative battery wire, and let it stand for a few minutes, then when I connected the battery back up the check engine light came on, and the vehicle started. Ran for about one minute then shut off again. Check engine light did not come on as it shut down, and was not on when I turned the key back on. I removed the PCM fuse outside under the hood, let it set a minute and put it back in. When I turned the key on, the check engine light came on and the car started when I tried to start it. It ran for about 45 minutes then shut off again, doing the same thing. I again removed the fuse and replaced after a few minutes and it started up again and ran. Where do I need to start to look for problems?
Old 01-08-2006, 06:18 PM
|WYG|SS |WYG|SS is offline
Re: 1997 Sunfire start problems
chack the fuel pump or the relay to the fuel pump!
Old 01-08-2006, 08:02 PM
Checked and it is working properly.
Old 01-29-2006, 08:03 PM
fritz314 fritz314 is offline
Send a message via MSN to fritz314 Send a message via Yahoo to fritz314
Try taking out the muffler and starting my 96 had the same problem but it was the catalytic converter-it was clogged and not getting enough air I had to replace the whole exhaust system
Old 02-13-2006, 03:58 PM
Smile Re: 1997 Sunfire start problems
UPDATE: I disassembled the wiring harness and found a kinked and broken wire under the front of the vehcile, inside the protective wrapping. Red wire was also broken. It ran from the camshaft sensor to the PCM. Cut it out, soldered in a new piece of wire and vehicle now appears to work fine.
