Old 01-08-2006, 03:59 PM
gtmossy gtmossy is offline
1991 Plymouth Voyager wont start!! HELP!!
My son has a 1991 plymouth Voyager...it has had stalling issues for years...nothing was ever found why???? Now it will not start at all!!! My husband has changed the fuel filter....it has spark...when gas is put in the intake it starts. Any help would be appreciated...dont want to spend a forune fixing!!
Thanks!
Old 01-15-2006, 11:48 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 1991 Plymouth Voyager wont start!! HELP!!
Thanks!
Sounds like a bad fuel pump. Can you hear the fuel pump whine for about 2-3 seconds when you turn the key to the "on" position?
Old 01-17-2006, 04:36 PM
jblair1948 jblair1948 is offline
Try turning the key to on, wait till you hear the pump cut off, then turn it
to on again, repeat this about 10 times before you try and start the eng.
Then try and start the engine. Or if you know what your doing, you can
bypass the fuel pump relay (temporarily).
I had this problem on my 89. What happened to me, and I think you, is that
there is a check valve in the gas tank with the pump. The check valve is
leaking and you are loosing pressure when the van sits. So now when you
try to start it, the 2 sec. of pump on before you try to start the eng. is not
enough to build up the pressure. As you try to crank the eng. the injectors
are bleeding off the pressure as fast as the pump can make it, so the net
result is you aren't getting enough fuel.
You will get a good reading on a pressure gauge if this happens.
I also think you have a problem with a dirty Throttle body and the Idle
speed motor on the TB. Get some carb cleaner and really clean the
TB out. You may want to take it off the car so you can really clean it.
But as was said you'll need a new pump. I don't know about the 91s but
my 89 has a "replaceable pump" or a replacement assembly. Do NOT put
in just the pump (if available). It won't have the check valve. Plus it's
a lot more work.
My 95 only comes as an assembly, pump, sending unit, etc.
Let us know how it goes.
John
