Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-08-2006, 03:17 PM
hkostman hkostman is offline
2000 Sub 4x4 door panel removal
How do I remove the door panels on a 2000 Sub 4x4 3/4 ton to install new speakers?
Thanks HK
Old 01-17-2006, 12:39 PM
ocjmakaveli ocjmakaveli is offline
Re: 2000 Sub 4x4 door panel removal
Thanks HK
Pretty easy just pop off the handle trim and pop off the window switch gently UP then there's 2 screws to remove i believe 7 mm one is above the handle and the other one is viewable when you remove the window switch.
Once those 2 screws are removed just lift the panel UP because it has hooks that hold it on then when removing disconnect a few connectors and that's it.
Old 01-20-2006, 10:15 PM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
OC is right, it may feel like your breaking it when you take it off, you just have to have a feel for it.
Old 01-23-2006, 12:26 PM
xzphatboizx69 xzphatboizx69 is offline
Is this the same for a 2002 Z71?? I can't get the panels off either.
Old 01-24-2006, 10:23 PM
Should be, make sure you get all the bolts out first, i usually roll the window all the way down because you may have to lift up a little to get the panel off the truck. Pry at the bottom in case you break something its harder to notice at the bottom. Hope this helps.
Old 01-28-2006, 09:21 PM
hartshorn hartshorn is offline
Cool Re: 2000 Sub 4x4 door panel removal
See this site for some clues on how to remove the door panels.
I replaced the hinge pins on both doors by completely pulling the doors off my 1995 Suburban. The job took about 5 hours total. Doors swing as smooth as glass and do not sag anymore.
http://www.muthco.com/techsupport/pdfs/21000040.pdf#search='1995%20suburban%20door%20pane l%20removal'
