Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-08-2006, 01:50 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Testing alternator voltage regulator??
Just wondering how I would go about testing the voltage regulator on my alternator? I have it removed from the alternator, so i was wondering if I could use a multi-meter or somehthing to make sure its good.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 01-10-2006, 08:43 PM
knorwj's Avatar
ok, how about this then since nobody knew. Will the voltage regulator from an aftermarket 80 amp bosch alternator be interchangable with the OEM alternators voltage regulator?
Old:
New:
Newer:
Old 01-10-2006, 10:29 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Testing alternator voltage regulator??
http://img.photobucket.com/albums/v4...n/93tegalt.gif
http://img.photobucket.com/albums/v4.../93tegalt2.gif
Don't know if it will help, but I hope it does.
Edit: that was messed up, should be fixed now.
Old 01-10-2006, 11:46 PM
kcg795 kcg795 is offline
You need a microscope to read those. That definently won't help this guy.
Old 01-16-2006, 11:15 PM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
view the image fullsize, not scaled to fit IE and you can read them fine
Old 01-16-2006, 11:26 PM
CivicSpoon's Avatar
There is no Spoon
It was actually my fault, some how when I uploaded the files, they were tiny. I believe it was the size of the file (too many mb's), and photobucket resized it. But I shrunk the size down by saving them as jpgs, and they work now.
