I have a 1997 Dodge Avenger auto. with the 2.0 420A motor. Im wanting faster shift time. I have takin it to the 1/4 to see what I can get and the car hits 7000 rpms and sets there for awhile and then shifts. I have found out around 5000 rpms is my best. I want it to shift at 5000 rpms not 7000 anymore and shift faster with no delay. Are there any shift kits out there for the Avenger auto. tran. I would love to put a turbo on the car but with the way it shifts my afraid I will blow the motor at that high of rpms. ANY HELP PLEASE!!!!!!
Thanks Jesse |
I have a 98 Avenger ES V6 auto. I am not sure if the transmission is the same in the 4 and the 6 cylinder but I had a shift kit put in mine. I believe you can get them from TransGO. Register and search Aseclub.net, ASOG.net, and EXILERacing for parts and info. They cost like $50 and I dont think they need to pull the transmission to put it in. It goes in underneath just by taking off the tranny pan so labor shouldnt cost much. With my shift kit in the car shifts stronger and a little harder under acceleration due to pressure increase. The car even chirps the tires in 2nd gear. I have other mods though and a V6 but I would say its worth it. Another good upgrade is to get a torque converter. Like a 2500 stall Heavy Duty one, like $300 plus install. I have heard people say that it should be the number one upgrade for Avengers with automatics.
Re: Wanting faster shifting
Why would you want to shift at 5000?
The engine doesn't come up to full horsepower (140) until 6000rpm. It seems like 6500 would be a good shift point. The shift point is computer controlled, so you can't really do much about it. I have a shift kit at home for the Dodge FWD 4-speed auto. I bought it for my minivan but I haven't had it put in yet. Cost $32 I think. Dodge uses the same 4-speed auto for most of it's FWD cars/vans. The 2.0 doesn't perform well with it b/c the trans wastes a lot of torque running the hydraulic pump. The larger engines barely notice, but the 2.0l doesn't have any torque to spare. Adding a shift kit might actually slow you down some b/c the hydraulic pressure is increased and that causes more torque loss. A turbo would prabably work well with the setup though. The trans is rated 250hp and 250ft lbs torque. With the kit, it should hold about 300hp I would think. |
Re: Re: Wanting faster shifting
The shift kit is better for the transmission and prolongs clutch life because harder shifts dont slip and wear out the clutch packs. I highly recommend you get a transmission cooler too. Heat just kills an automatic transmission and it is definetly worth it. They dont cost much and you could put one on yourself, starting around $25. Dont worry the shift kit wont slow you down, it is a good upgrade and lots of people have it. Seriously look into the torque converter though. Avenger autos are slow off the line. A high stall converter will make it accelerate a lot faster. Just Curious, How fast is your Avenger?
well hey now auto avengers arent that slow off the line most people just dont know how to baby them off the line. cuz ive beat a 5 speed avenger and he got a good launch. most people just mash the gas or they hold them at 4500 rpm well if you hold it at 3500 you get a great jump at least i have on all my races with a grand am gt,5 speed avenger, and a buick ultra everytime i held at 3500 hundred i jumped them. so just learn to baby it off the line it works trust me
1997 Dodge Dakota Sport 1995 Dodge Avenger 1980 Corolla Sr-5 (hornet creature)
You can race but it doesnt mean you are that fast. What do you run? Stock Avengers run low 17s I think. My Stealth runs a 13.6 quarter and once you drive one you wont think your Avenger is fast anymore.
well i never hold the break down...But anyway i know avengers are slow off the line. That why im buying a chrysler conquest quicker launch. But yeah i know from my info on stealths there faster then a roadrunner with a rocket up its ass
now wait, if your not holding the brake down then what are you doing... your not neutral dropping are you? the trannies in those cars arent the greatest and if your doing that its not gonna last very long at all.
to the thread starter, you dont want to shift at 5000, you will drop out of your power band if you do that. see when you shift at 7000 it drops you right back into your power band. probably doesnt take you below 5000. i suggest you dont change that shift point. however i do think it would be a good idea to invest in a shift kit, and i think its a much better idea to invest in a tranny cooler, they arent expensive at all. i too am curious, what do you run now. what you should do is save about $3k and buy yourself a turbo kit along with the tranny cooler/shift kit. |
hey stang!!! but yeah i start from no revvs we honk it 0ff and i start from around like the 2500 hundred mark cuz i dont touch throttle until the last second and i hold it down and my tires catch then i let off a little so my tires dont spin unlike all who ive raced around here with there greats amount of spin. so yeah thats all i ever get to race is novices who watch way to many tv shows so they watch like f and f then there all hyped up in there grand w/e and i blow there doors off with my screwy technique. but yeah i could prolly be faster if i used break but i dont wanna wreck mt daily driver. i'll try different techniques with my other car
A couple of things to think about how the launch can be affected.
At speeds under 9 mph, torque management program is running. Torque is limited and applied only at a certain rate of gain, to avoid hurting the trans and spinning the tires. This is more pronounced in the larger v6's that put out torque close to the limit of the transmission, it may not apply to the 2.0l. Also, at throttle 80% or more (varies with application) the computer retards ignition timing about 6 degrees and runs rich fuel mixture to keep cylinder head temp down, after 15 seconds on some engines the timing it retarded again and more fuel is dumped in. Up to about 75% throttle, when it is time to shift, torque management reduces the torque during the shift. Because some power is still being produced, you can feel the thump into the next gear. At WOT power is completely shut down during the shift, you will see the tach drop instantly as the shift occurs but you will not usually feel the shift at all. Some people have cut the "request for torque management" wire that goes from the transmission to the engine controller. You must install the shift kit if you do this or the transmission will be toast in no time. Expect tire barking, neck jarring shifts if you do this. |
^^ looks like someone knows their trannys...
Guys, I don't know if you are noobs at street racing or just don't explain your racing techniques very well. Some of the descriptions you guys give make me lol :=) , you are going to break your car or lose the race b/c of silly techniques.
You can race a car on a regular basis and it still be reliable, unfortunately I don't think you guys are in that club, sorry no insults intended, you guys just make my day. I assume you are young and inexperieced at the car thing. |
