Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-08-2006, 12:03 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
How big of a winch do I need?
I've been looking at winches because I tend to go wheeling by myself. The only thing I've gotten stuck in so far was some really deep, wet snow... and I think I was high centered by some ice. So, I don't need a huge, frame curling winch. I just want something that could pull the jeep out of some small situations. What is the smallest rating that I could get away with? Do I need one with an 8000lb. rating? thanks!
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 01-08-2006, 12:19 PM
Kuhn's Avatar
Re: How big of a winch do I need?
I just read someplace that you should multiply your gross vehicle weight by 1.5 to get the minimum pulling force for a winch. Does this sound right?
'98 Eclipse RS
Old 01-08-2006, 01:55 PM
Ray H Ray H is offline
Re: Re: How big of a winch do I need?
This is true but stating it in terms of gross vehicle weight is a little misleading. the Jeep has an official GVWR, this has nothing to do with winch size recommendations. The minimum winch pull rating should be 1.5 times the weight of your vehicle and the maximum cargo you will be carrying. Generally minimum winch pull rating for a Jeep is 6000lbs. That gives you 4000lbs for the Jeep and cargo. If you modify your Jeep or carry tools or lots of camping gear, you will quickly exceed 4000lbs, that moves you up to the next winch size, 8000lbs.
Not many people would recommend that you go off roading alone but if you do, your winch is now your 4X4 buddy that you depend on to get you out of tough spots. Just like your human buddies, make sure the winch is dependable. Dont skimp on it or your asking for frustration. What if you got stuck and your human buddy just stood there and refused to help you, you would be pissed. Same thing with a winch.
Ive got an 8000 Warn on my Jeep and personally, I wouldnt go smaller or cheaper.
Old 01-08-2006, 01:59 PM
alphalanos alphalanos is offline
Yeah I always go overkill on anything I buy, and consequently, none of my tools/ parts have let me down. Id say get the best one you can afford. (Ex. I bought an 8,000lb jack for my Civic lol)
96 EJ6. Future home of boosted B18C1.
Old 01-08-2006, 02:05 PM
Oh, another point. A winch isnt a toy. Its probably the most dangerous piece of equipment on the trail. Make sure you use it safely, ALWAYS, not just sometimes.
And a winch is only as good as its accessories. This means dont forget to pack shackles, tree savers and snatch blocks, the more the merrier. Also make sure your tow points are up to winching. The winch and cable is only as good (and safe) as the point its anchored to.
Sorry to go off topic but it sounds like you want to save money. There are better places to save money than on your winch system.
Old 01-09-2006, 12:20 PM
Kuhn's Avatar
What fairlead is recommended for synthetic rope? ...I don't want to be cut in two if the line snaps, so no wire cable for me... Thanks.
'98 Eclipse RS
Old 01-09-2006, 02:38 PM
An aluminum hawse fairleads.
