Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 01-08-2006, 11:55 AM
barkboy6 barkboy6 is offline
'85 SS Fuel Problem
My 85 has not been running right for over a month now and I can't figure out what's wrong. It runs and drives fine for about 30 minutes or so, then it acts like it is running out of gas. I've replaced the fuel filter, MAP sensor, EGR valve, ignition module, and the fuel pump. I took it to a mechanic and he diagnosed the fuel pump problem and replaced it, along with some vacuum hoses with pinholes.
It ran good after the pump replacement and I thought it was fixed, but it started up with the same problem. I took it back and he found/replaced another hose with a pinhole, yet it is still not fixed. The car is 20 years old and had been sitting in a garage for about 2 years before I bought it. What other areas of the car might I check out that could be causing this problem? Could the plugs and wires be the cause? The car only messes up after it gets warm, maybe something is failing only after it heats up?
Old 01-08-2006, 02:37 PM
maxwedge maxwedge is offline
A990 racer
Re: '85 SS Fuel Problem
How about the filter in the carb inlet?
Old 01-08-2006, 03:14 PM
Re: Re: '85 SS Fuel Problem
I haven't checked that at all. Where exactly is it, and how can I tell if it needs to be replaced?
Old 01-15-2006, 04:01 AM
99grandgt's Avatar
99grandgt 99grandgt is offline
Send a message via AIM to 99grandgt Send a message via Yahoo to 99grandgt
sitting for two years, its gonna need replaced. it is in the carb where the fuel line goes in...jsut inscrew it and put a new one on/in. if its a q-jet.
"haze grey and under way!!!"
99 honda odyssey
99 grand prix gt
possibly a g8 gt when i get to cali
