Old 01-08-2006, 11:21 AM
75anders 75anders is offline
Rear blower control failure
My windstar -00 rear blower doesn't work. The fan works when hotwired directly and on relay sockets(excludes the resistors?). The relays work separately when tested with 12v on manouver connections. It seems like I get no control voltage to the relays. I do get 12v to the relay mains.
Any Ideas someone?
Old 01-08-2006, 04:25 PM
12Ounce 12Ounce is offline
Re: Rear bower control failure
Are you saying the motor runs if you jump over the resistors?
Another poster had to replace the resistor pack.
Old 01-08-2006, 04:44 PM
Re: Re: Rear bower control failure
No the resistors are fine, so are the relays and motor. It seems like the relays that feeds the resistors dont get there manouver voltage.
Old 01-08-2006, 08:35 PM
Seizer's Avatar
Seizer Seizer is offline
The fan doesn't run at all? Or will it run in one speed only? Just curious I had a similar problem with the rear blower not letting the relays close. My fan ran in low speed no matter where I put the blower selector. In my case it was a bad fuse. I have wiring diagrams for 2001 Windstar, if you would like a snapshot of it for this circuit let me know and I will do my best to get it to you.
Old 01-09-2006, 01:33 AM
No It doesn't run at all unless I put a jumper wire over the relays. I would love to get a wire diagram!
